ducatipaso.org • View topic - Adopters between 320mm rotors and 750 Paso M1R?
It is currently Mon Sep 29, 2025 10:20 pm
 Post subject: Adopters between 320mm rotors and 750 Paso M1R?
PostPosted: Fri Feb 05, 2010 4:53 pm
Does anybody have any drawings, fotos, etc... from such adopters what can be used for 17" conversion with normal Paso 750 M1R forks and 320mm rotors from newer Ducati(SS/Monster, etc) with those 17" Ducati wheels???
I have used adopters between Paso original forks and 4 piston black coloured Brembos(from 907IE), original 750 Paso rotors in my 750 Paso with very good results, but if change to 320mm rotors then i have to find/make new adopters....
I quess, that someone, like "Mr G" have some drawings in his pc... :) But all input is welcome... :mrgreen:
 Post subject: Re: Adopters between 320mm rotors and 750 Paso M1R?
PostPosted: Fri Feb 05, 2010 6:47 pm
just look in my downloads thread on top of this forum.
PostPosted: Sat Feb 06, 2010 9:16 pm
Finn,
Here are a few jpg's that I created for you. First shot is a custom bracket that was made for me for my 750 sport.
These were hand made brackets without drawings so I do not have exact measurements.
Second image is a drawing I made on 2mm spaced graph paper.
The fork brackets are spaced vertically at 107.66 mm and have a 2mm horizontal offset to the right.
The top caliper hole is 35.43mm down from the top fork hole and 2mm to the the left of center on the fork holes.
The lower calper hole is 27.75 mm from the fork center line and 13.09mm offset from the lower fork hole.
Sorry for the inaccurate measurements. The guy who did these did not produce a cad file for me and roughed them out by hand. At least this will put you in the ballpark and give you a working example.
Joe
1990 Ducati 750 Sport (mine)
2007 Piaggio BV 500 (mine - daily driver)
2008 Piaggio MP3 500 (wife's)
My Ducati Blog site
http://projectducati.blogspot.com/
Stupidity is not a crime, your are free to go ;-)
PostPosted: Sun Feb 07, 2010 12:39 pm
This bracket is for the calliper with 65 mm spacing :
PostPosted: Sun Feb 07, 2010 1:06 pm
Pitty that those are for 65mm spacing, as i am looking adopters for 40mm spacing(black ones from 907/early851). I want to keep those black ones still in bike, as they are more rare compared to "new 65mm ones". :) Anyway good drawings...
Nilaus, i think You should change new steel braided lines to Your Paso, as those old rubber ones can be already too old and braking sensitivity with new lines is from "another planet". I noticed such when i changed to steel braided lines in my P 750 (and also in 907) ;) Original rubber ones are not so good at all... at least after 10 years...
PostPosted: Sun Feb 07, 2010 1:19 pm
Found it :D
viewtopic.php?f=1&t=1551
Look for : " brake adapters for 300/320mm discs on Marzocchi M1R fork (calipers with 40mm mounting hole distance) "
:D
Or go to: http://www.box.net/shared/gj6cbxn48w
PostPosted: Sun Feb 07, 2010 1:28 pm
Thanks! Just what i was looking for... I tried to find it after Gerhards note, but couldnt...hahahaha... my fault! :)
PostPosted: Sun Feb 07, 2010 2:02 pm
oh come on Antti, it`s just on top of the P750 forum :)
Nilaus, don`t forget that your front discs are still missing some screws.
PostPosted: Sun Feb 07, 2010 4:15 pm
As i told, my misteke :banghead: I tried to find it from "Ducati Paso 750" part, and it was in "general"... Sometimes i am too hurry and very stupid, but i can say it here... :mrgreen:
PostPosted: Sun Feb 07, 2010 8:43 pm
PostPosted: Mon Feb 08, 2010 12:53 pm
Never mind, the discs only needs a couple to stay in place :lol:
No you can bet your life on, that they are all there. The mid picture was just a mock up.
:beer:
Users browsing this forum: No registered users and 34 guests
