ducatipaso.org • View topic - clutches and coils
It is currently Thu Oct 02, 2025 1:18 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: clutches and coils
PostPosted: Mon Feb 22, 2010 1:31 am
My clutch on the 907 is getting a little louder these days. i read up on Barnet kevlar clutches. Anyone tried them? and should I also replace the clutch basket.
Still trying to determine if I need 3 or 4 ohm coils for my 907. I was going to purchase Dynas Any help is appreciated
Preston
 Post subject: Re: clutches and coils
PostPosted: Mon Feb 22, 2010 2:51 am
Barnett seems to be the main choice for replacement. Price varies a lot on ebay.
I think the plates the friction surface is attached to is alloy , so a small weight saving.
The desmo times book says the basket is ok as long as its not notched by the clutch plates wearing into the sides. Thats the chatter noise.
I have replaced my basket with the MPL Tuning along with a MPL slipper clutch. All up its a lot lighter, supossedly will let the motor spin quicker, whatever!
Haven't riddden it more than 500m as I am doing other stuff [!!!], however in that short distance its very apparent that the slipper has changed the bike a lot, no where as much jerk when you lift off, also the bike is quieter on the over run as the bake wheel is not engine braking like a truck.
Big loss of Ducati character maybe, but i wanted the safety on downchanging, also prevents over reving. Clutch wear is greater as in traffic the plates get a lot more use.
As I have limited experience I am sure others will post
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Mon Feb 22, 2010 9:15 pm
Clutches: Ducati replacement is not that much more than the Barnett. Remember the factory clutch basket is steel. The factory plates are steel. They do make alumin. drive plates (the ones with the tabs and the friction material). However, if you mix the alumin. with the steel basket, the alumin. tabs will wear down much faster than the factory steel ones. There are several aftermarket manuf. that make alumin. clutch baskets. It makes sense, use steel with steel and alumin. with alumin. I have had both and I have gone back to the factory clutch because it lasts longer. Also, the original paso basket is slightly different than the part no. replacement that is basically the same as the 900ss, 916, etc. The bottom is slightly flat whereas the newer replacement is rounder. So the plate staking is slightly different with the new basket.
du907
PostPosted: Thu Feb 25, 2010 8:17 am
PostPosted: Thu Feb 25, 2010 4:45 pm
Quite normal as the clutch starts to wear. From time to time remove the clutch cover and blow out the area with compressed air to remove the dirt and clutch plate dust.
Dry clutch noise is all part of the experience of riding a Ducati :mrgreen:
Joe
1990 Ducati 750 Sport (mine)
2008 Piaggio MP3 500 (wife's)
My Ducati Blog site
Stupidity is not a crime, your are free to go ;-)
PostPosted: Thu Feb 25, 2010 7:14 pm
Joe,
Clutch rattle is such a feature of Ducati that you need to share it. Hence the after-market clutch covers with all the cut-outs, holes, penetrations etc.
Let everyone hear it and share.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Thu Feb 25, 2010 8:29 pm
The mod I speak of stops the rattle but ( by virtue of the fact that the rattle is no more ) stops the hammering / wear on the clutch basket , plates and the hub as well. If any one is interested I'll sort some pix and an explanation.
I bought and fitted a new clutch basket , plates (sureflex sintered bronze ) and hub . The rattle was still so loud that I felt there was no point in fitting them and off they came and the old stuff went back in , with the mod and as you can see my clutch plates are very worn , but yet no rattle. the wear visable all occured b4 the mod was done. The basket and hub are in similar condition
PostPosted: Thu Feb 25, 2010 11:33 pm
I'm not opposed to the clutch jingle, but it has gone from sounding nice to obnoxious. I thinks this weekend I'll see if there is any dust in it. I do have a vented cover on it and have always like the noise the clutch makes, as that is one of the things that makes it a Duc.
Does anyone know for sure what the coil resistance should be. If not I guess I can check that this weekend also. I have planned to put a set of Dynas on it. I have planned a 1500 mile ride for April and am just wanting to eliminate any problems like old coils and old wires, and a little too much jingle.
Preston
PostPosted: Fri Feb 26, 2010 2:33 am
My Ducati Blog site
PostPosted: Fri Feb 26, 2010 3:24 am
My book sez that the primary winding should be . 34 ohm , which I thought was a typo and should be 3.4 ohm, so to be sure I measured the ones on my paso and they are both 0.4 ohm , so the book was right at 0.34 ohm ( +/- 10% ). before spending bulk $$ why dont you try the mod posted by others here ( think it was in higgy's webberology 101 .... not sure ) where a direct feed is run to the coils and magic box vai a relay ( similar to a head light relay setup ) ... solves a problem of low voltage to coils / magic box, well worth trying 1st , and only cost for a relay and a bit of wire
PostPosted: Fri Feb 26, 2010 11:25 am
Any coil in the 3 to 5 ohm range is safe. Anything less than 3 ohms will burn out your ignition module. Warwick has added a very detailed howto on coil related upgrades to our Weber doc. You can find the weber doc here in the documents section or here
PostPosted: Fri Feb 26, 2010 8:37 pm
beats me ! I have a 74 850T Guzzi which has had a point ignition sinse day one and has been very happy , but when I fitted a dyna ignition module both the ( 3.5ohm) coils and the module got real hot so I fitted a 1.6 ohm ballast resistor to each coil ( in series ) which improved things . I have sinse bought some dyna dc10-1 coils but havnt tried them yet. the only thing I can think of is that the dyna module must be powering the coils for longer ( in crankshaft degrees rotation ) than the points did .
PostPosted: Sun Feb 28, 2010 10:12 pm
One thing I'd add RE the clutch it *don't* assemble per Barnett, assemble per the Ducati book, IE, start with a friction, then a steel, etc, all the way out. You may be short a friction plate, if this is the case use the first plate from your old set - if you have a OE Ducati plate this will be thicker than the others.
I think Barnett based their clutch instructions on newer Ducatis, which have a slightly different hub. The 907IE hub has a flange on it which keeps the first metal plate from engaging if there's no friction plate on the bottom.
If assembled as above you have the normal beloved Ducati rattle when you pull the clutch in, but it silences as soon as you release the clutch. This is the way it's supposed to be.
Sam
PostPosted: Mon Mar 01, 2010 9:00 pm
Putting a friction plate in 1st is the whole guts of the Quiet clutch mod . The hole in the centre of the friction plate ( fp ) is large enough to fit over the clutch hub and the tangs on the fp sit in the grooves in the clutch basket
the whole idea is that the 1st fp sits further out than the hub ( by 1/2 mm) so that when the 1st steel plate is fitted it sits against the 1st fp , not the back of the hub .I bent the tangs on the 1st fp to get this measurement right
When the clutch pack is assembled, spring pressure forces the pack against the 1st steel plate which pushes against the 1st fp , the tangs of which are now pushed into the bottom of the basket grooves thus binding the basket and hub together so no more rattle
As you can see the 1st fp fits over the hub ,with the tangs in the basket grooves . An old clutch plate will do . If you bend the tangs to much the clutch will feel queer and will not completely disengage and if you dont bend em enought the rattle will still be there.
The broken spring posts are as a result of the prang , I think my foot must have been squashed ( It sure got squashed some how ) between the clutch cover and the car which pushed the cover in against the still rotating clutch , snapping all the posts off :mad:
PostPosted: Tue Mar 02, 2010 12:07 am
Sam and Mctool, Great instructions and pics of the quite mod. I will most definitely perform the mod when the clutch goes back together.
Joe
My Ducati Blog site
