ducatipaso.org • View topic - Anyone fitted frame sliders on their Paso?
It is currently Fri Oct 30, 2026 12:02 am
 Post subject: Anyone fitted frame sliders on their Paso?
PostPosted: Sun Nov 08, 2009 5:18 am
If you have I would love to see some photos of where exactly you've attached them to the frame and hence which part of the fairing you had to the cut holes out.
Thxs
'87 750 Paso 751412
 Post subject: Re: Anyone fitted frame sliders on their Paso?
PostPosted: Fri Dec 04, 2009 7:37 am
Judging by the lack of response after over 60 views to my question
I've surmised that none of us are willing to cut holes in our Pasos :shock:
'87 750 Paso 751412
PostPosted: Fri Dec 04, 2009 9:05 am
Are You?
Could you make a plate attached to the frame, so the slider bolts through one of the current bolt holes where the fairings are currently attached by the well nuts?
You would have to work out where it would rub by laying it over.
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Fri Dec 04, 2009 4:38 pm
Its my understanding that the sliders need to be bolted directly to the frame and they only come
out so far plus being about the same size as a skateboard wheel its looking like a job for a hole saw.
I thinking that if they are attached to a plate that is bolted to the frame they might just fold over thus
defeating their purpose. Plus the bolts used to mount them are fairly thick.
So that is why I'm hoping someone has already successfully crossed the river on this one.
Thanks for the response
Easy - E
'87 750 Paso 751412
PostPosted: Mon Dec 07, 2009 10:08 am
Under body sliders work far better unless you are looking just to protect the body in the case of a parking lot tip over. Through body sliders will catch in the dirt if the bike low sides at a decent rate of speed and slides off the road, once the sliders dig in the bike may well start flipping causing way more damage than no sliders at all.
Here's the ones I use on my SS
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Fri Feb 26, 2010 8:30 am
'87 750 Paso 751412
PostPosted: Fri Mar 05, 2010 8:20 am
The problem is the risk of doing it !
1. you have to cut holes in body work
2. If you bolt to the frame and the bike goes down you porbably save the bodywork but qwreck the frame.
3. if you bolt to a hradpoint in the frame like and enging mount is it in the right place ? - if not will it just tip the bike over when its sliding and therefor put the tank on the ground etc.
4. Fancy testing it after you've done it ?
I did look at this about ten yeasr ago (I have a spare set of OE bodywork to play with) but just couldn't answer most of the questions above. Havign also seen the effects of some cheaper sliders I can say that point 2 is particularly relevant
