ducatipaso.org • View topic - Swapping wheels to 17inch
It is currently Tue Sep 30, 2025 4:34 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Swapping wheels to 17inch
PostPosted: Sat Jan 16, 2010 9:54 am
I don`t understand why you lowered the fork. Only for not getting too close to the fairing ? How about the front cylinder under full braking?
The 907ie swingarm is longer so the steering angle already becomes steeper and as the fork is shorter the angle changes even more so from this point of view there`s no need lowering the front at all and you now dropped it another 15mm. This could cause steering wobble, specially at higher speeds.
Did you check chain alignment (w/ laser) or are the front sprockets of 906 and 907ie the same ?
PostPosted: Sun Jan 17, 2010 11:04 am
PostPosted: Sun Jan 17, 2010 3:52 pm
sorry, my misunderstanding. You were talking about dropping the fork, I understood dropping the front. I guess I should read better.
PostPosted: Fri Jan 22, 2010 6:35 pm
hi all,
I saw an ad. from a local Duc dealer who has halfrings you can put in the place of the original excenter of the rearaxle and make the swingarm longer.
just enough to adapt a 17" wheel.
look at www.startwin.nl
ducbertus
PostPosted: Fri Jan 22, 2010 7:05 pm
Can you check the link?
I have tried to see it, but I got an error message.
PostPosted: Fri Jan 22, 2010 7:09 pm
I'm just on to it.
http://www.startwin.com/
this is the URL. (I've checked it!!)
when I found the half rings I'm gonna post it.
ducbertus
PostPosted: Fri Jan 22, 2010 7:26 pm
these half rings are not on their web site yet.
I found their ad. in the Dutch Ducati club magazine.
with these half rings (kind of Omega shape) and longer bolts you can mount a Avon AV46
Azaro ST 150/80 ZR16 tyre. Reading this post I remember I had read the ad and thought it was to adapt 17". this is not soo. my mistake. :oops:
but maybe it's helpfull to someone. :)
halfrings and bolts cost € 100. you also have to elongate the chain by one link.
ducbertus
PostPosted: Fri Jan 22, 2010 8:44 pm
Can someone make direct link to those "half rings"???
PostPosted: Sat Jan 23, 2010 12:13 pm
they will be on their website shortly.
I called them and explained the guy I spoke there's a lot of interest in those halfrings.
He promissed to put the halfrings shortly on the website.
Ducbertus
PostPosted: Sun Jan 31, 2010 9:18 pm
WOW :shock: raise this , lower that, paso geometery, 20mm longer that !faaarrrkk what a head spin ! If I put a 17" wheel on the front ,it should raise the front,( who cares how much !) which is good , then do same for rear, also raised.... good ( I keep scraping that stupid cross thing in the exhaust so a bit more ground clearance is good ). If the wheel hits radiator ..... move the radiator ( the brackets are all cracked , so there's 2 reasons ). I think that any noticable changes in handling will be because of the 17" wheels / tyres rather than because of the changes in geometery caused by the fitting of said wheels /tyres. A little bit of the old " head in the sand " aint so bad ( just ask the pomm's, they won 2 wars doin' it ! :P )There is a bit of ride height adjustment at the rear using either the eccentric ( wether you set the axle hi or low gives a inch ) and there is adjustment available at the shock itself......... that will do me .
Hamish
PostPosted: Sat Feb 27, 2010 5:45 am
Does anyone know what size disks this calliper bracket is suited for?
It was made for 906 forks converting to 4 pot Brembos for a 17 inch hub, but i don't know what disk size they are for.
PostPosted: Sat Feb 27, 2010 8:47 am
as the caliper mounting holes are so far back they are most likely for 320mm discs
PostPosted: Sat Feb 27, 2010 11:34 am
Whats the word on the Halfrings?
I've tried using Google's translate on the web site but to no avail.
It still comes out Dutch.
'87 750 Paso 751412
PostPosted: Sat Feb 27, 2010 10:55 pm
thank you for writing in Arial 72.
now I don't need me glasses. :)
I've watched the website of Startwin several times, but any information didn't show up.
meanwhile I learnt to put pictures in a post.
using these half rings ables you to mount a 150/80-16 Avon tyre.
the chain needs another link.
Bertus
PostPosted: Sun Feb 28, 2010 10:15 am
OK Here's what it says:
Ducati Paso rear tyre problem is history.
Thanks to the rear fork adapters designed by Star Twin the 16" rear tyre problem is solved. Thanks to the extra space provided by the adapters you can now mount a Avon 150/80 ZR. The adapter kit comes with longer pinch bolts and the chain needs to be extended by one link.
Kit price 100 Euro
Installation (labour) 75 Euro. This includes lenghtening the chain.
Rear tyre 267.75 Euro
Complete set (incl. installation) 400 Euro
Users browsing this forum: No registered users and 46 guests
