ducatipaso.org • View topic - clutches and coils
It is currently Wed Oct 01, 2025 6:52 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: clutches and coils
PostPosted: Tue Mar 02, 2010 6:12 am
What I did ( eventually ) to get the right bend in the 1st fp was to over bend the fp , assemble the clutch and then , with a soft faced hammer , tapped around the circumfrence of the pressure plate , which bent the tangs back to the " correct dimention " . Honestly , I @#$%ed about for ages bending and straightening , assembling and dissassembling before " taking to it with a sfms hammer " ( soft faced medium sized........ Hi Antti :P :lol: :lol: )
PostPosted: Tue Mar 02, 2010 7:28 am
PostPosted: Tue Mar 02, 2010 11:40 pm
PostPosted: Wed Mar 03, 2010 3:04 am
PostPosted: Wed Mar 03, 2010 3:32 am
I have been told that I have cast iron lungs ,of larger than usual capasity , by an amazed looking knifeholder as a spot the size of luxemburg was comsumed without waisting even the smallest tendril :lol: :lol: :thumbup: those were the days
PostPosted: Wed Mar 03, 2010 11:22 am
PostPosted: Fri Mar 05, 2010 11:47 pm
PostPosted: Sat Mar 06, 2010 12:23 am
1990 Ducati 750 Sport (mine)
2007 Piaggio BV 500 (mine - daily driver)
2008 Piaggio MP3 500 (wife's)
My Ducati Blog site
http://projectducati.blogspot.com/
Stupidity is not a crime, your are free to go ;-)
PostPosted: Wed Mar 10, 2010 9:44 pm
hey McTool,
while reading the post I was missing your pics of the bend tangs.
can you repost them? :)
thanks in advance and good luck with plumbing and don't to much iron. it stiffens you're poo and you got clogged like never before. :evil:
see you,
Ducbertus
PostPosted: Thu Mar 11, 2010 4:06 am
I put in the light weight basket and clutch plate today. Made the motor sound different, I guess due to the 2.5 lb. reduction on the crank. Still have some jingle, and I'm sure it will increase with time.
I also put in a hi-lo hid lampset in the stock headlight. Major improvement over the old h-4 bulb, and I suppose draws about 20 watts less.
PostPosted: Fri Mar 12, 2010 4:31 am
Got any pictures of the HID modification? Would like to see 'em.
du907
PostPosted: Fri Mar 12, 2010 10:05 am
i have bought these for my bike and car, just haven't fitted yet!
http://www.jaycar.com.au/productView.as ... rm=KEYWORD
[NB Australian site]
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Sat Mar 13, 2010 2:11 am
I didn't take pictures, but it was a very simple install. The ballast assy. mounts to the voltage reg plate directly next to the regulator. There is 3 prong adaptor that plugs into the existing headlight bulb plug. The low beam is hid, high beam is halogen. Low beam is more than adiquate for riding even at high speeds. I think it was a great improvement and an easy retrofit and only $49.50
Get the 6000k beam. Does not effect on coming traffic, or at least I had no one flashing at me to dim my lights.
http://cgi.ebay.com/ebaymotors/Motorcyc ... 2a0148b685
PostPosted: Sat Mar 20, 2010 1:45 am
PostPosted: Sat Mar 20, 2010 2:09 am
I posted this sentence in an earlier post, "Also, the original Paso basket is slightly different than the newer part no. replacement that is basically the same as the 900ss, 916, etc. The bottom is slightly flat whereas the newer replacement is rounder. So the plate staking is slightly different with the new basket."
Your pictures above show exactly what I was talking about. Notice how the bottom of the slot is rounded at the bottom and the tang can only go down so far, so you are bending the tang in order to get the plate to sit different. The original 907 basket's groove is flat at the bottom and the first plate sits a little farther down than what you pictures show here, thus making the stacking a little different that other Ducati models. Does any of this make sense? I'll see if I can find the original clutch basket and take a picture and post it. Maybe you will see what I mean.
du907
