ducatipaso.org • View topic - Cam Timing
It is currently Mon Mar 02, 2026 1:46 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Cam Timing
PostPosted: Wed Mar 03, 2010 11:47 pm
In talking with the folks at Nichols, since he has started doing this service, he hasn't found a bike that did not benefit. Some timing was off by up to 8 degrees. I don't know how this can happen with the design, but I guess it can. If this is true with newer bikes, I can only imagine how the older bikes are.
There was a good write up on the affects of cam timing, or as they say, degreeing the cams.
It was at Moto One, in Australia, but the link no longer works. I guess they are gone, and so is all of their data and website. shame.
PostPosted: Thu Mar 04, 2010 8:43 am
 Post subject: adjustable pulleys
PostPosted: Fri Mar 05, 2010 1:25 am
PostPosted: Fri Mar 05, 2010 5:31 am
 Post subject: Re: adjustable pulleys
PostPosted: Sun Mar 07, 2010 5:16 am
PostPosted: Sun Mar 07, 2010 6:06 am
PostPosted: Mon Mar 08, 2010 10:27 pm
PostPosted: Thu Mar 25, 2010 5:42 am
Ken , thankyou very much , I also had an idea that I might get a set of heads " done " to go with a set of 95 mm pistons and a set of fcr's I'm still working on but as I say I couldnt contact them
thanks
Hamish
PostPosted: Thu Mar 25, 2010 9:36 am
PostPosted: Mon Mar 29, 2010 4:06 am
PostPosted: Tue Apr 13, 2010 2:16 pm
Ok, Kens excellent file is now ready for download (it can be found via my downloads thread, it`s not on the sites downloads yet). Here the direct link.
PostPosted: Tue Apr 13, 2010 3:45 pm
Will also be available from my site shortly
Outstanding file. Very nicely done.
Add to the list of potential solutions is the Nichols pulleys, that have 4 different keyways cut into them. That and some offset keys and its a $150 solution.
I had the cam timing done on my ST4s, and it improved the mid range nicely. Now on to the 750 and 900 motor.
PostPosted: Fri Apr 16, 2010 2:25 pm
just saw this on ebay
http://cgi.ebay.de/DUCATI-BEVEL-BELT-DR ... 19bb6d6a64
 Post subject: My Cam Timing
PostPosted: Mon Apr 26, 2010 8:27 am
My settings were:
Vertical cam:
Inlet Opening BTDC 13.5; Inlet Closing ABDC 59; Inlet Duration 252.5; Inlet Centreline 112.7
Horizontal cam:
Inlet Opening BTDC 25; Inlet Closing ABDC 66.5; Inlet Duration 271.5; Inlet Centreline 110.7
Adjusted as close to the 106 centreline preferred settings as I could get:
Vertical cam:
Inlet Opening BTDC 29.25; Inlet Closing ABDC 62; Inlet Duration 271.5; Inlet Centreline 106.36
Horizontal cam:
Inlet Opening BTDC 30; Inlet Closing ABDC 62.5; Inlet Duration 272.5; Inlet Centreline 106.2
It seems my Horizontal cylinder Inlet Centreline was at the Ducati factory specs of 110 degrees, though the vertical was a couple of degrees out. So, I have adjusted both cylinders, as close as I could get, to the Bikeboy 106 recommendation as per Ken's Cam Timing document.
Results:
Starts straight away - the reluctance to start that I had is gone :) . I have ridden the bike on local roads, motorway and open road and am convinced the 106 cam timing is far better. The power is lower down - more accessible for normal driving. I like it since I have to contend with traffic lights and mostly drive under 100kph :). On the open road I can do 150kph in 4th with power to go, so no problem as far as i will ride it.
No noticeable difference to air fuel mixture (AFM) on the rear, but the front, which was 2 degrees retarded needed jetting back in line with the front cylinder.
Thanks Ken for the superb Paso Cam Timing document and the other help given. I am a newbie, so if I can follow this I figure anyone can. :D :beer:
