It is currently Thu Oct 29, 2026 7:15 am
 Post subject: 1988 Paso swingarm alloy
PostPosted: Thu Apr 22, 2010 2:57 pm
Hi to all,
Does anyone know what alloy Ducati used on the swingarm?
I am going to modify it to accept a larger tire. I will post results as I progress.
Thanks, Vince
 Post subject: Re: 1988 Paso swingarm alloy
PostPosted: Sun Apr 25, 2010 4:28 am
Yeah , I'm pretty sure its an aluminium alloy :P You could always ask fredskidoo, he has already modified his for "sprocket clearance" :lol:
There are ways to fit available tyres to your paso without chopping the swing arm, have a look at some of the recent posts .
PostPosted: Mon May 03, 2010 5:05 pm
A very common aluminum alloy for extrusion is 6061. Other alloys can be extruded, but the range is rather small. I would have to assume that since the Paso was in small production numbers, and made as a production bike, that they chose a very common alloy.
Here's a link:
http://www.midstal.com/sft334/aluminum_ ... alloys.pdf
I don't recall the common alloys for casting, but a websearch may give you the info you need.
