ducatipaso.org • View topic - Paso valve adjustment
It is currently Tue Mar 03, 2026 3:16 am
 Post subject: Paso valve adjustment
PostPosted: Fri Apr 30, 2010 11:16 pm
Are there any resources (other than the factory manual) that instruct how to set Paso 750 valves?
Thanks, Vince :banghead:
 Post subject: Re: Paso valve adjustment
PostPosted: Fri Apr 30, 2010 11:29 pm
Two of many
PostPosted: Sat May 01, 2010 1:06 pm
Higgy,
Thank you!
Vince :beer:
PostPosted: Sat May 01, 2010 2:14 pm
One note: As stated in those articles, there are many ways to measure/adjust valves and i take allways belts away from my bike, as then its easy to rotate camshaft from upper pulley to find just right "area" to get feeler gauge in. I dont want to make any "war" about thiskind things and everybody can measure and adjust they valves how they want .... Then same time its easy to check belts condition much easier as they are out. I turn engine from left side by taking that small cover away(2 screws) and by putting simple "M8 screw tool" (M8 screw with one nut for locking this screw) to end of cranksaft and normal 13mm wrench to that "M8 screw tool" to turn engine to get marks to they right positions. Many ways to do valve job... :thumbup: :beer:
PostPosted: Sat May 01, 2010 5:31 pm
If you are new to Ducati as I am, there is an excellent video about adjusting valves located here
http://www.youtube.com/watch?v=dIj3nSJGPZw
PostPosted: Sat May 01, 2010 6:47 pm
Very easy job, when sylinder heads are out from engine :lol: :lol: :lol:
PostPosted: Sun May 02, 2010 6:33 am
