ducatipaso.org • View topic - starter motor - engine case seal (and brushes)
It is currently Wed Jun 17, 2026 12:31 pm
 Post subject: starter motor - engine case seal (and brushes)
PostPosted: Sat May 15, 2010 8:59 am
just had to take starter aprt - brushes worn out
so starter rotor has been pulled about to get end cap and starter case off (need to clean up commutator)
Assume there is an oil seal between strater and LHS enigne case?
Will this need changing now?
Also any source of new brushes or complete brush holder in UK?
(found holder on ebay in USA)
ta
Dave
 Post subject: Re: starter motor - engine case seal (and brushes)
PostPosted: Sat May 15, 2010 4:15 pm
PostPosted: Sun May 16, 2010 2:56 am
PostPosted: Sun May 16, 2010 1:06 pm
thanks
better get on with it then
PostPosted: Fri May 21, 2010 4:00 pm
maybe you`re lucky on the brushes
viewtopic.php?f=1&t=2573
