ducatipaso.org • View topic - New here
It is currently Thu Mar 05, 2026 11:56 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: New here
PostPosted: Tue May 25, 2010 2:30 pm
My rear shock bit the dust, and I was told by there weren't any rebuilds available for it; I bought a unit which I actually purchased (new) from their ebay store at a pleasant discount. I've only got a hundred or so miles on it so far (after 2.5 years of not riding the bike), so I'm still reacquainting myself. This was the cheapest replacement I found; I think I paid about $300 shipped via ebay (I think the shock lists for ~$475 retail).
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Tue May 25, 2010 3:54 pm
I am thinking about buying The Works Performance as well.
PostPosted: Fri May 28, 2010 11:42 am
Welcome, bike looks sweet. I am also newish now, this is a brilliant forum :thumbup: :thumbup:
but do search and read the tech notes in all the forums.
The Wilbers is not cheap :shock: , AUD$1100, it does have lots of adjustment and for another AUD$400 you can add a hydraulic pre load adjuster. [Easy adjust for pillion or luggage]
The cannister , in my case because of the angle they fitted the hoses, now goes on the left and I fitted the pre load to the rh rear peg, [drilled and tapped] to hold. We had to guess the length of the preload hose as Wilbers had no spec, I went for 50cm, was perfect! Fluke!
It being there means I can reach it to adjust preload with my luggage strapped on.
Wilbers asks your weight, riding stlye and usage and the sets the shock and spring to suit.
Preload was perfect and you would only play with the adjustments if your were tracking or had a lot of weight on board, like pillion and luggage. You now maintain the correect steering geometry and won't rub a big hole in the under tray!
The Penske was about $USD900 I think.
Quite a few original shocks on ebay at times, for $50 or so. Then wait for a second hand Penske to come along and get into a bidding war :lol:
I had my other shock rebuilt, [2nd bike] but it was complete.
You may be able to rebuild it without the adjuster working any way.
One thing about your tyres having a worn flat profile is that, in my case, I found that the bike was a real pig to turn at low speeds. New Metzlers and it was transformed. I remember commenting about the famous Ducati slow steering was a pain, but it was just poor tyres!
A tyre should be thrown away after 6 years, they loose 1/2 their grip after 3 years.
This was highlighted on a DCOV [Duke Club of Victoria] ride to Tasmania last year. A rider went down when the tryes lost grip for no apparent reason. They found out that despite the tyres being new , they were in fact over 6 years old! Sat on the shelf for a long time....
There is a DOT code on the side showing week built and year, Eg 1009, would be week 10 2009, 4597 = week 47 1997.
Tyres are you life, don't be cheap :!:
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Fri May 28, 2010 12:29 pm
In regards to a shock for the 750 Paso: I contacted Wilbers and received this. Not so helpful, but there is contact info for the US: :phone:
Hi Randy,
I am out of the country on vacation this week with limited computer access. I return tomorrow and I'll be in touch then.
Thanks for the inquiry, I'll get back to you with information.
Ted Porter
Wilbers America
Scotts Valley, CA.
Direct Cell: 831-420-7776
-------- Original Message --------
Subject: Ducati 750 Paso monoshock
Date: Mon, May 24, 2010 6:50 am
To: info@wilbersamerica.com
Greetings:
Can you fabricate a shock for a 1987 Ducati Paso? Ballpark Price? Lead
Time?
Thanks and Best Wishes,
Randy Castellon
PostPosted: Sat May 29, 2010 11:34 am
In Oz I gather they don't sell too many wilbers shocks, most likely similar to the states,
so the local dealer is a one man show, that does a lot of suspension work, but has tme off!
Have a look at the web site, there is a link to Wilbers in Germany.
It took about 6 weeks for mine to arrive from order date, but then he only does one shipment a month I think.
this is the link to the shock
http://www.asr.com.au/products/631a.php
Nigel
Lambretta LI150 S3
87 928S4
PostPosted: Sun May 30, 2010 6:01 am
The Wilbers US guy got back to me:
HI Randy,
Unfortunately there is no listing for the 750 Paso, only the 907 Paso has a Wilbers listing.
However Wilbers will prototype and hand build a shock for you. They do not charge extra to custom build a shock, but you would need to either send them your old shock, or be willing and able to give them the technical specs they require such as shock stroke, suspension travel and so on.
If you would like to pursue this further, it would be best for you to contact the factory directly. They have a very friendly and helpful english speaking person who is willing to answer your technical inquiries at:
USA@wilbers.de.
Typical pricing is $569.00 for an emulsion style shock with manual spring preload and rebound damping adjust. Up to $849.00 for a three way damping adjust model with high and low speed compression adjustability and a remote reservoir for maximum performance.
Wilbers shocks have a five year warranty and are fully rebuildable. They are hand built in Germany and are very high quality.
Thanks for the inqiury, let me know if I can help further.
Best regards,
Ted Porter
Wilbers America
Scotts Valley, CA.
831-438-1100
Good to know...
Best, Randy. :beer:
PostPosted: Sun May 30, 2010 1:19 pm
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Great, even if a good craftsman could manage to overhaul yours for a fraction of the cost.
PostPosted: Sat Oct 02, 2010 1:27 pm
Users browsing this forum: No registered users and 40 guests
