ducatipaso.org • View topic - Paso 750 Rear Tire solution (160/60/16)
It is currently Thu Mar 19, 2026 10:06 am
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 18  Next
 Post subject: Re: Paso 750 Rear Tire solution (160/60/16)
PostPosted: Thu Jun 03, 2010 5:52 am
my feeling: 180/60 16 = good. 160/80 = not so good :thumbup:
PostPosted: Thu Jun 03, 2010 5:58 am
Thank you, Mike, for that excellent vid.
What a great road! I had never heard of it ...
Erskine
PostPosted: Thu Jun 03, 2010 11:20 am
http://www.youtube.com/watch?v=0nrMQ3QwyPo
One of the coolest videos ever! :thumbup:
PostPosted: Thu Jun 03, 2010 8:06 pm
Very nice twisty road and great Goldwing's rider.
The only thing I don't like is the 4 cylinder noise of the bike on the background :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Jun 04, 2010 4:40 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Jun 04, 2010 9:14 pm
despite the fact that this tire will never fit on a Paso according to the Avon website the 160/80-16 is recommended for 3.50-4.50 rims, the 150/80-16 for 3-4.00" rims so both would be fine on the Pasos front rim :mrgreen:
PostPosted: Sat Jun 05, 2010 7:01 pm
I did not go for the Shinko but instead ordered a Metz ME880 160/80-16 for my 750 Sport and I will try this on ASAP (which translates to 2-4 weeks due to my busy schedule). I will however not continue posting here in the Paso forum, but keep to the 750Sport to avoid confusion. Is that better? :cool:
I will compare it to the present 160/60 Mich that has lots of threads on it and actually change back and forth for a good comparison. On the front will be a new 130/70 since the present 120/80 (!) from the prevsious owner is long overdue.
And to let you know even little more about me: I am really carefull with changing dimensions on my tyres and I am also very well aware of things like tyre pressure, ride hight, sag, weight and load distribution front-back and so on: I do 15-20 track days per year in the fastest group on my 900 SSie (that is converted to 100% track bike), so I think I should manage to get you some good feed back on this. IF it is wanted that is. At the moment I do not feel like it is really appreachiated though. :(
750Sport -88 (undergoing surgery)
Pantah racer
450D mk3 -69
900SSie -02
PostPosted: Sat Jun 05, 2010 7:39 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Jun 07, 2010 7:44 pm
Guys, I made now approx 2000 km with the following tire combination:
Front: Metzeler SPORTEC M3 FRONT 130/70 ZR16
Rear: Avon Cobra AV72 180/60 R16 TL
Marvellus combination. We have a lot of corners in Switzerland an I guarantee you, you will not regret going for the Avon. Much more grip than the Original Michelin. I used it so far almost to the Edge (missing 1-2mm) which means more slope than the original michelin ever afforded (under normal conditions). In combination with the Metzeler Sportec which has a round profile superb and neutral handling. It really underlines the quality of Paso chassis.
Even if I could get a brandnew set of Michelins (which is not possible) I would never go back to it.
pasoalf
Paso 750/ 1987
Paso 906/ 1992
PostPosted: Mon Jun 07, 2010 11:39 pm
PostPosted: Tue Jun 08, 2010 4:53 am
PostPosted: Tue Jun 08, 2010 7:47 am
pasoalf, why did you mix brands ?
PostPosted: Tue Jun 08, 2010 6:51 pm
To make it work with a 180 I made an alu spacer 8.4mm , put it in-between the sprocket and the plate and i put an 41 crown instead of 40 to compensate the gearing ratio because of the bigger diameter of the 180/60/16.
I did some documetation, which I wanted to post a long time ago. But I'm actually very busy. I'll put it at the forum soon.
I mixed brands because I wanted to have the best front tire solution. According to Avon the Cobra is build up like a sport tire but it's not a real one. So I had a look at all suitable dimensions of front tire and read some tests. The sportec seems to be a very good tire, so I ve chosen this-one for the front wheel.
Even before I've always ridden a different tire in front. The 130/60/16 was a real bitch (just try to break in a corner...)
So even before it was flat I moved to a Metzeler Laser (120/80/16) in front. I made approx 35'000 km with the Metzeler front and the Michelin behind and the bike behaved much better. Better handling, stability and completely neutral.
So I think the fary tale that you should not mix brands is from a epoch where the moste motorbike chassis still where shitty.
Moreover it's alowed to mix brands front/rear in switzerland. You just are not alowed to mix diagonals and radials.
pasoalf
Paso 750/ 1987
Paso 906/ 1992
PostPosted: Tue Jun 08, 2010 11:52 pm
Also mixed brands, esp front, w/o major problems on my M900.
But always the recommended size.
The Sportec is a very good tire, grip enough f any Paso riding.
PostPosted: Wed Jun 09, 2010 1:41 am
Shinko tires on sale at Cycle Gear
130/70-16 Podium 006 Front $87
http://www.cyclegear.com/spgm.cfm?L1=50 ... _87-4021_G
Couldn't find the rears.
Cheers.
