ducatipaso.org • View topic - Whats this ? Seal or Bearing !!!
It is currently Wed Apr 29, 2026 2:44 pm
 Post subject: Whats this ? Seal or Bearing !!!
PostPosted: Fri Jun 11, 2010 7:23 pm
This is a picture of the shaft that the two cam belt pulleys are on.(92 907IE)
Does any one know if the round black part around the shaft is a oil seal which can be easily replaced or is it a bearing cover ?
I have a small oil leak which i think is from this shaft :cry:
Bomber :thumbup:
 Post subject: Re: Whats this ? Seal or Bearing !!!
PostPosted: Fri Jun 11, 2010 9:30 pm
It is a seal that can be replaced from the outside. My 907 leaked there after a shop rebuilt my engine. They said they didn't replace that seal and sure enough it started leaking. I took the bike back and they replaced the seal while I waited. It took them about two hours. I think they may have drilled a hole then used a sheet metal screw in the hole then pulled on the screw to get it out.
du907
PostPosted: Fri Jun 11, 2010 10:54 pm
the seal has a metal kind of cup inside.
when you insert a wood or chipboard screw you can pull it out and replace without major disassembly.
or drive a screwdriver behind the seal and lever out the seal.
good luck,
Bertus
PostPosted: Sat Jun 12, 2010 12:12 am
It is a seal.
PostPosted: Sat Jun 12, 2010 6:47 am
Thanks Guys, :beer:
Just the information I needed, will attempt to remove the seal by the screw method :thumbup:
Regards
Bomber
