ducatipaso.org • View topic - Busted Display Needs Replacing
It is currently Mon Mar 09, 2026 10:40 pm
 Post subject: Busted Display Needs Replacing
PostPosted: Sat Jun 19, 2010 6:31 pm
Hello all,
The clips on my '87 750 Paso display became brittle and broke so now the clear cover comes off. I called the nice people at DucatiOmaha about getting a replacement, sadly those aren't available anymore; I have also checked with local dealers and junk yards but nobody has one either. :banghead:
I searched through the forums here and found a post in early 2007 from ducapiero about connecting the fuel indicator to an Acewell display. Unfortunately the photobucket pics are no longer good so I don't know what it looks like. :,(
I'm in the market for a new display, any suggestions on which would be good alternatives?
:dunno:
Mark
 Post subject: Re: Busted Display Needs Replacing
PostPosted: Sat Jun 19, 2010 7:25 pm
It will be very hard to find a new dashboard screen.
You'll find easier the whole dashboard which sometimes appears on ebay.
PostPosted: Sat Jun 19, 2010 7:52 pm
If the cover is basically in one piece just the clips are gone you can carefully reinstall it with some clear silicone sealer. Place a small bead low on the bezel then lower the cover onto it so that the excess rolls out on the bezel and not up into the cover. Let it dry for 24 hours and then trim off any excess Scratchs can be repaired with flame polishing...BE advised flame polishing takes lots of practice on some thing other than your hard to replace cover. :thumbup: Mapp gas works best but if you have never done this sort of thing I would start with propane and when you have practiced practiced practiced move up to mapp gas and practice some more Once you have learned to apply the heat evenly without inducing bubbles in the plastic move onto the cover. You can remove even scratches big enough to catch a nail with this method and it will look better than new when done properly.. The Vietnamese Gentleman (Phong) that taught me could join two pieces of acrylic together using nothing but mapp gas and make it look completely seamless. I have nowhere near the eye for flame polishing Phong had,but I can make most scratches disappear in about 5 minutes. Some day I might even try it on a pair of eyeglasses :beer: :beer: :beer:
PostPosted: Sat Jun 19, 2010 11:44 pm
Try Ian Gowanloch in Aust.
http://myworld.ebay.com/italsparesducati/
He was selling complete dash units.
PostPosted: Wed Jun 23, 2010 10:01 am
Yep, Ian Gowanloch sold me a brand new one only several weeks ago,and fairly cheap too.Give him a try. Rgds. Jay.
PostPosted: Wed Jun 23, 2010 12:15 pm
In The US you can try Ed ducpower
PostPosted: Tue Jun 29, 2010 1:31 am
I made one from clear plastic ( I wanna say perspex but Im not sure what it was ) and ultraclear araldite , by shaping the main lense and then, by heating and bending, form a " rim " which I then glued on. A previous owner spilt brake fluid on the lense
PostPosted: Sat Sep 04, 2010 10:31 pm
OK, so I used Guerilla Glue to fix the display, got it up and running for about 2 weeks before the key switch/ignition stopped working....GRRRR!!!! :banghead:
I placed an order with Ducati Omaha to buy a new one but it's been discontinued...again GRRRR!!!! :mad:
Ebay and Craigs List have both turned up nothing so I e-mailed ducpower.com to see what they may have, wish me luck!
PostPosted: Sat Sep 04, 2010 11:40 pm
PostPosted: Sun Sep 05, 2010 8:12 am
you can try to fix it yourself.
http://www.box.net/shared/4evp1px5be
PostPosted: Tue Sep 14, 2010 9:28 pm
PostPosted: Wed Sep 15, 2010 9:07 pm
PostPosted: Thu Sep 16, 2010 12:01 am
