ducatipaso.org • View topic - Mirror question
It is currently Tue Apr 28, 2026 2:02 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Mirror question
PostPosted: Wed Jun 23, 2010 11:12 pm
Gert,
They are referring to the break away style of mirror as opposed to the bolt on style...two different mounts.There is also a two piece mirror and a three piece. The three piece mirrors are all bolt on. Some of the two piece are bolt on some are breakaway style. The only advantage I see is in a tip over the break away will not rip out large hunks of your precious bodyworks,it will however still give you lots of cracks to fix and repaint :banghead:
PostPosted: Wed Jun 23, 2010 11:31 pm
OK.
The only good one is original one w one whole housing that does not separate except fr front plate
to axcess bulb etc.
All others are bad imitations & quite ugly IMHO.
PostPosted: Wed Jun 23, 2010 11:48 pm
PostPosted: Thu Jun 24, 2010 5:30 pm
when you wreck the original mirror by throwing your bike down you'll find out that the metal base plate stays on the fairing. yes, bolted down.
however the mirror body self sits on small brackets gripping around studs on the base plate. I'll post a picture of the wreckage.
The FAR mirror has a different, more simple construction with only a base plate fitted to the mirror body.
Bertus
PostPosted: Thu Jun 24, 2010 9:22 pm
Bertus
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ESELX%3AIT
PostPosted: Thu Jun 24, 2010 9:45 pm
thx,
I found it yesterday evening.
tried to upload my pics of the wrecked mirror, but ended in a battle with Photobucket. to be continued.
Bertus
