ducatipaso.org • View topic - Paso 750 Rear Tire solution (160/60/16)
It is currently Fri Mar 13, 2026 12:36 am
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 18  Next
 Post subject: Re: Paso 750 Rear Tire solution (160/60/16)
PostPosted: Wed Jun 09, 2010 3:50 pm
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Wed Jun 09, 2010 7:11 pm
@Mike:
you are using the podium and the 747 on your bike, is that right?
do you know if there are any differences to the 757 you are refering to?
as far as I understood you did not to any modifcations to the chainline to fit the shinko 747 180/60.
how did you get that to work? just grinting some rubber of the tire away?
thanks for your input and gretting from switzerland, hardo
PostPosted: Wed Jun 09, 2010 7:14 pm
@pasoalf
great to hear from you again. since I life in switzerland too (not aournd the corner but no big deal anyway) I would certainly like to drop by and see how you did the modification to fit the avon.
did all your problems work out? you mentioned wheel bearing problems and the size of the avon made you some problems in respect to the swingarm too as far as I remember.
any contact with the mfk so far.
PostPosted: Thu Jun 10, 2010 5:07 am
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Thu Jun 10, 2010 9:56 am
that's an idea as well, scrape tyres thinner, but, will this not affect the tyre dureability?
PostPosted: Thu Jun 10, 2010 11:46 am
PostPosted: Sat Jun 12, 2010 5:39 am
@Hardo,
Paso750 mentioned it, the wheel bearing problem was because of a missing wheel bearing spacer. (never give your bike or parts of it to a mechanic...) I also mentioned earlier that I did offset the sprocket, but it also turned out that my front sprocket was mounted the wrong way around (same thing as mentioned above, never give ....)
Anyway that made it even easier.
The swiss specific stuff (MfK aloud tire dimensions) is probably not of general interest. But it's probably wise to not make the rear tire "flat". So you still have an option to show up at the MfK.
I' ll send you my privat E-Mail and handy No. If you are interested in showing up, no problem. I can give you all the necessary details. You even can have a ride to look how it feels (I anyway would like ones to ride a 906, could be probably a future replacement...)
pasoalf
Paso 750/ 1987
Paso 906/ 1992
PostPosted: Sat Jun 12, 2010 6:46 am
PostPosted: Sun Jul 04, 2010 2:45 pm
who sell in europe this SHINKO tyre? 180/60 r18 :wacko:
I can't find out anything on internet...only USA retailer, whit expensive shipping cost...
Ducati Paso 906 grey 1990
Bmw K100rs 4v rot metallic 1992
Aprilia Tuareg Rally 1986
PostPosted: Tue Jul 06, 2010 11:24 am
Avon Cobra Achter 180/60 R 16 ?.? bar
Avon Venom R AM42 Achter 180/60 R 16 2.9 bar
Bridgestone Exedra G704 Achter 180/60 R 16 2.9 bar
Dunlop D250 Achter 180/60 R 16 2.8 bar
Dunlop Elite III Achter 180/60 R 16 2.8 bar
Metzeler ME880 Marathon Achter 180/60 R 16 2.8 bar
these you can get in Europe....
PostPosted: Tue Jul 06, 2010 8:47 pm
many thanks joeltje but I have read that the shinko are thinner than the others listed?
and on the 906 can works whithout "modifications"
maybe I have found out where to buy them in germany.... I am waiting for a definitive answer :smoke:
PostPosted: Wed Jul 07, 2010 9:23 am
PostPosted: Wed Aug 18, 2010 4:25 pm
I got a Shinko 150/80/16 reartire for my Paso. Shinko SR743 to be more precise. Just rode it today for about a 175 km´s and it seems to working fine.
Only modifications needed were a longer chain (108 links instead of 106) and a bigger rear sprocket (40 teeth, instead of 38). With this combination I was able to get a decent amount of adjustability on the chain/tire-thingeys.
I still have the Michelin 130/60 on the frontwheel and I think the combination handled nicely. Guess I´ll be going with the michelin for the rest of this season and swap to a Shinko 130/70/16 during the next winter.
PostPosted: Thu Aug 19, 2010 9:54 pm
Hey Pasoist
is the Shinko you fitted a sport tyre or sport touring?
Clive
PostPosted: Thu Aug 19, 2010 9:55 pm
cool, that's really good to know
