It is currently Sat Jun 20, 2026 11:21 am
 Post subject: flat battery
PostPosted: Mon Aug 23, 2010 5:21 am
Hi, my 750sport has a flat battery;can i charge the battery without removing from the bike
 Post subject: Re: flat battery
PostPosted: Mon Aug 23, 2010 5:36 am
Yes, but you need to add a charging connection to the battery. If you buy a trickle charger, most of them come with a pigtail that you can attached to the battery and simply plug in when not in use. I keep most of my bikes on a battery tender when I'm not using the bikes much. I find the Sport to be really good on batteries. If your battery is several years old, it may just need to be replaced.
PostPosted: Mon Aug 23, 2010 5:43 am
thanks,the charging connection will i have to buy from a bike shop or can i get from a retail store?jas
PostPosted: Mon Aug 23, 2010 9:31 am
Any automotive supply can get you a pigtail for a trickle charger.............
