ducatipaso.org • View topic - 907 EPROM
It is currently Mon Sep 29, 2025 12:27 pm
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: 907 EPROM
PostPosted: Thu Jan 14, 2010 1:23 pm
The 023U is the USA kind of the chip with a leaner carburation.
The 023 is the EU kind a little bit richer.
PostPosted: Fri Jan 15, 2010 6:28 pm
Here is a EPROM programmer that I got off of ebay. As I stated in the posting above I adjusted my TPS and balanced my throttle bodies. When you adjust the TPS you never can get it exactly back the way it was. So after getting everything adjusted my 907 was running way to lean. So I needed to get a chip that would make my engine run richer across the board. So a fellow on the internet offered a couple of bin files that he had made custom for his 907. I researched the OEM chip and model number and bought some locally and programmed them. The chip works great as stated in the posting above with the dyno chart. Anyway, enclosed is a picture of the programmer. It is an Enhanced Willem EPROM programmer. It comes with the windows software and both serial and USB connectors and cables. You can use either one, I just have them both plugged in for illustration purposes. You put the chip into the light green socket in the middle and set the dip switches according to the software. The LEDs are indicators for the voltages and etc. It has been awhile since I did this and I am no expert so I wouldn't be a good source for questions. I just thought this might help.
PostPosted: Mon Aug 30, 2010 4:33 pm
On my 907 I earlier this year gave up a bit on the mini MyP8 as I could not get it to run properly. Have an LC-1 O-2 sensor and plan to get the Optimizer over Winter and give it another try. I think mainly my ignition table was wrong, and I tried many.
In the meantime I have borrowed a USBIII Power Commander and wonder if any of you have a proper working map for it?
I have used it with both my FIM chip and with the original 023 lately using the LC-1 to indicate a direction, but have not had on a dyno which seem to be the way to go.
Per
Copenhagen,
Denmark
PostPosted: Tue Sep 07, 2010 12:00 am
I recently rebuilt my motor because I couldn't get it to run steady with the FIM chip, very jerky except at full throttle. After the rebuild to 944 cc and 10.5 compression, it still didn't run right. I ordered a custom chip from FBF for $150 US and the bike runs great now! I was able to give them all the modifications and based on their extensive dyno testing they gave me something that is pretty close to optimal. I have been getting 50 mpg at 80mph on the highway with a 39 tooh rear sprocket as well. Well worth the money!
PostPosted: Tue Oct 12, 2010 11:01 pm
We dont care about mileage, give us the hp/torque numbers! ;) :lol: `
Just saw was is possible in chiptuning nowadays.
My friend, who`s turned into an ECU wizard, showed his latest tricks on my bike w the P7.
First, w a chip emulator & Tuneboy, he was mapping the bike while it was running!
We altered idle fuel to check for real.
Second, he put in a chip w a larger 4k bit chip on top of that. W just an electronic switch,
he switched from the complete (fuel, ignition, start map etc) E23 map to whole FIM map, then to next and so on, 5 in total. And, while the bike was running! One could have up to 16 chips/whole maps in one chip. :shock:
PostPosted: Thu Oct 14, 2010 12:13 pm
Local Oz product
http://www.bikeinterceptor.com/products ... nterceptor
You add it into the system, splicing into [by connector] the fuel injection wire to the injector. Basic only adjusts fuel, advanced unit also does ignition.
I gather you would need a O2 sensor, or a sensor in the exhaust.
I saw it on the race super bike, Motologic, and it certainly looked pretty with all the graphs etc.
Has a USB stick as the data logger, so you can check out the performance after.
AUD$550. This may be the next toy :evil:
The talked about the ECU chips having to satisfy emmissions more than performance, so most bikes run lean midrange so to pass the tests. I would think that this would apply to our 907s
I am having valves adjusted and the TPS, throttle bodies set up, pick it up tommorrow.
Its interesting that the mechanic said usually he sets up mixture by riding the bike to get the best result! [different company to the interceptor business]
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Sat Dec 25, 2010 3:14 pm
PostPosted: Sat Dec 25, 2010 9:01 pm
Hi Nick,
great to know you manage to do such work.
I guess, once you have dumped the stock map, the next step is improve it.
Here, there will be many variables depending by the shape of the engine, its modifications (mufflers, air filter...) etc.
Interesting work, but hard, too :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: .
I would'nt know where to begin... So, let me/us know.
PostPosted: Wed Dec 29, 2010 10:00 am
In experience the hardest part was to understand how the maps are structured and what real world meaning have the values stored in EPROM.
As I was mapping a particular engine in its final configuration, it was relatively easy to end up with a good configuration within reasonable time. I was observing AFR with wideband sensor and knocking with earphones connected to a knock sensor via earphone amplifier. For my (automotive) application it worked like a charm.
Nick
PostPosted: Wed Dec 29, 2010 2:15 pm
PostPosted: Thu Dec 30, 2010 8:22 pm
happy new year antti may spring come early to finland! :thumbup: :cool: :)
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Sun Jan 02, 2011 8:24 am
hi all...I finally replaced the chip, a ferracci stage one (exhaust only chip), re-assembled everything put my helmet and gloves on turn the key...no FI pump...starter motor ok :dunno:
...then I thaught the chip must be the wrong way around, turn chip around, tried again...still no go :huh:
...fit old chip back on, no problem, fired up straight away :dunno:
obviously the chip has some sort of brain damage...after all this time I was looking forward to try it out :banghead:
this chip was from FUEL INJECTED MOTORCYCLES
BPS 0% Staintune 907
new chip FBF stage one
Looks like it will be a few weeks before they will send another one, so much for their quality control :wacko:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sun Jan 02, 2011 4:06 pm
Let us know about the replacement...
PostPosted: Thu Jan 13, 2011 4:32 am
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Thu Jan 13, 2011 9:51 am
Quite easy.
Just remove ECU, open it & replace chip.
You could buy a special set of pliars that grips it in the best way
or maybe an electrocins/cumputershop can help.
But it is as easy as it looks... :wink:
