ducatipaso.org • View topic - 19.90 paso 750
It is currently Mon Sep 29, 2025 9:51 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Post subject: 19.90 paso 750
PostPosted: Sun Sep 05, 2010 5:32 am
Please help!@!!!
i just bought a 1990 750 paso . been stored for approx 12 years. Started it up and it has severe bigend rattle. has compresion
both pots. I dont know full history , by the noise i suspect rear bigend - piston . Is this normal with this model ? do they have bigend trouble ? . The guy i bought it of said that it was ok when running last many years ago .Other than that it is not to bad for its age. When i bought it i was not expecting to do a complete rebuilt !! looks lijke i will have no chioce. Any advice would be most welcome. Kind regards Roy
 Post subject: Re: 19.90 paso 750
PostPosted: Sun Sep 05, 2010 8:25 am
Hi Roy,
if it was stored for 12 years did you just fire it up as it was ? If so that could be the reason.
If the engine wasn`t turned over or started once in a while the cylinder walls can become bone dry and there`s the posibility that the piston rings stick to them.
One should do a full service (incl. belts!), squirt a little oil in the cylinders and turn the engine over by hand a few times before trying to start it.
It`s hard to say what it is. I personally didn`t hear of bigend troubles yet. (unless problems with exhaust valves) The engines are quite robust if regularly serviced.
Cylinders and pistons are discontinued and chances to find new ones are rather low. Also used ones don`t appear so often, but there`re some guys who are parting out their bikes.
I guess you won`t have another option then starting with pulling off the head.
PostPosted: Sun Sep 05, 2010 10:47 am
PostPosted: Sun Sep 05, 2010 10:15 pm
Are you sure you are not mistaking the trademark rattling clutch with loose big end?
All the suggestions above are solid, and stand for any motor stored for a long period of time.
PostPosted: Sun Sep 05, 2010 11:04 pm
Hi guys thanks for your in formation. I did spend a bit of time on the bike before starting it new oil , lube in the pots and turned it over many times be fore i started it. I tried to pull in the clutch lever while it was running it did not stop the rattle. I check both sets of valves all ok both cylinders have compression about 70 psi each. I think as you suggested i will remove heads and start from there. I am in Australia i was not aware that parst are so hard to get
PostPosted: Mon Sep 06, 2010 5:06 am
G - Can I assume that a good piston manufacturer (Wiseco, Mahle) can produce Paso pistons? They may need the old one to see the basic shape, and the clearances should be readily available. I would think that a piston is a relatively straightforward item to produce.
For the cylinder, ditto for LA Sleeve or comparable for new plating? Possible/advisable to install a cast iron sleeve?
:beer:
PostPosted: Mon Sep 06, 2010 8:01 am
That`s a good question. I don`t know if these manufacturers have all the measurements to manufacture Paso pistons. One would have to ask.
PostPosted: Sat Sep 11, 2010 9:52 am
Paso Engines are VERY VERY VERY close to the M750-SS750 engines.
the MAIN difference is in the CRACKSHAFT, the Clutch and some parts of the Gearbox and of course the heads where the Paso has big valves and the M750-SS750 has smaller valves.
Pistons are more or less the same,and any OEM or aftermarket (wiseco/ferracci/pistal) piston for SS or Moster 750 will fit the Paso 750.
I have an Old Elefant 750 engine dated around 1987-898 which was extremely similar to the PASO engine and which I modified adding:
- Paso Heads with BIG Valves.
- M620 Conrods (they were new and EXACTLY the same as the Paso750)
- Paso Primary gears with straight teeth (original engine had helicoidal teeth)
- Secondary Gearbox shaft of the M600 (its longer and allows to have the sprocket "outwards"
- a Mix of gears coming from different engines in order to have a "close ratio" Gearbox.
- Ferracci pistons 13.1 slightly machined to match my superhot NCR camshafts.
- Ferracci flywheel
- adjustable cam-gears for MODERN cambelt profile (round teeth)
- FCR39 carbs & ignitech programmable ignition.
Most of the parts had either polishing or shotpeening treatments.
As for the Cylinders, once you get the pistons the re are companies out there that will RE-CHROME and machine them tu suit perfectly the new pistons; i had mine done in Italy (same company that does them for BMW and Ducati) , but there are many others that provide the same service worldwide.
Last , There is a Chap in Autralia who can , for sure, fix your bike, you can reach him through his website http://www.bikeboy.org
Hope this helps.
PostPosted: Sat Sep 11, 2010 1:33 pm
Damondarwin's user name seems to suggest that he is in Darwin (in the Northern Territory). If this is the case he is about 3700 km from Bikeboy's shop! :) Having said that, I have heard that Bikeboy is very good.
Mike
PostPosted: Sat Sep 11, 2010 2:38 pm
PostPosted: Sun Sep 12, 2010 7:47 am
PostPosted: Sun Sep 12, 2010 8:17 pm
PostPosted: Sun Sep 12, 2010 10:31 pm
PostPosted: Mon Sep 13, 2010 5:53 am
Hi mate i agree with you he would have known. I will; give credit to him when i contacted him to discuss my concerns that the motor was ( stuffed, ) and that i was not HAPPY , he refunded an amount that would assist me to complete a rebuild.
I am slowley pulling it apart , I have forgoten the lack of Quality that is apart of owning a Ducati. The last one was a 1974. 450 single desmo, and that was a vaibriating dog. So thirty years on i thought i will try again, with aim to restore and ride on rallies
Thanks for your reply
PostPosted: Mon Sep 13, 2010 10:42 am
Users browsing this forum: No registered users and 93 guests
