ducatipaso.org • View topic - Solution to rec/reg charging problems
It is currently Fri Apr 24, 2026 10:28 pm
 Post subject: Solution to rec/reg charging problems
PostPosted: Wed Sep 29, 2010 3:14 pm
 Post subject: Re: Solution to rec/reg charging problems
PostPosted: Fri Oct 01, 2010 12:59 pm
this is very cool info, thanks
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Fri Oct 01, 2010 1:49 pm
More info on how different ones work:
http://www.electrosport.com/technical-r ... stem-works
I have too limited knowledge to understand if this works f us,
where are you electric wizards, calling Finnpaso?!?
PostPosted: Thu Oct 07, 2010 3:42 pm
It will work. And better than stock!!
PostPosted: Thu Oct 07, 2010 6:20 pm
PostPosted: Tue Nov 09, 2010 3:31 pm
I talked to my dealer today.
Not a bad idea, is like checking tha manual sometimes.... :shock:
They nowadays sells 2 Shindengen units:
1 w 3 yellow wires & 1 w 2.
If I got it right on the 2 wire one:
Shindengen no SH579B
Duc sp part no 5404111C
130 Eu f that, 115 f 3wire.
2wire came in 2 versions: SS/M & 916/748, wiring differ.
No possibility f warning light on both IIIRC.
Edit: Shindengen no indicates NOT a FET reg, so I`m still a bit puzzled which to uppgrade to....
