ducatipaso.org • View topic - Carb convert.
It is currently Tue Sep 30, 2025 10:47 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Carb convert.
PostPosted: Fri Oct 22, 2010 10:16 pm
Hi
Has anybody scrapped the injection system and put on carbs instead?
 Post subject: Re: Carb convert.
PostPosted: Fri Oct 22, 2010 11:29 pm
PostPosted: Sat Oct 23, 2010 6:42 am
I agree, but I know someone does it for historic challenges.
I would'nt do any challenge with a Paso...
However, it would'nt be too hard, because you can employ all the parts of a Paso 906 which shares the same engine, but carbed.
PostPosted: Sat Oct 23, 2010 8:25 pm
PostPosted: Sun Oct 24, 2010 10:22 am
PostPosted: Sun Oct 24, 2010 10:47 am
I fully agree with you Frankie, overall the 907 is reliable I never had to push it and it always took me back home :thumbup: :thumbup:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sun Oct 24, 2010 4:50 pm
If 907 injection is maintained well and all parts function well, it beats absolutely all carburator systems(especially P7 in 907IE, as it was designed for factory racers, like 888 in that time period)... Most importand is cleaness in injection systems! I talked one time with such guy who have played and maintained injection systems at last 25 years and he told that 90% of injection problems are caused by DIRT and SHIT in systems. ...filters, filters, filters... and maybe after every 40 000kms injectors away to maintain table to such maintainer! Also injectors need maintaining..... :smoke:
PostPosted: Mon Oct 25, 2010 12:02 am
P7 is a primitive ECU that needs a Memory board to have adjustable chips
& it has no offset map.
P8, in 888 from -93 has that, much better.
FCRs are wonderful, I love them in my M900.
But I wouldn`t try to convert my 907 to carbs, anyway, to much trouble.
Just consider wiring, ignition etc.
PostPosted: Mon Oct 25, 2010 9:58 am
the conversion is simple, you need:
- a 600-750 (carbed/kokusan version) flywheel and pickups; alternatively you can use the 907ie flywheel but you will need to modify it (15 minutes job) buy removing all the trigger lumps except one which has to be in a "specific position" easy to find by comparing it with a 600-750 flywheel.
- Ignitech Module + Dyna Coils
- MiKuni carbs or FCR carbs.
- a good set jets & needles
- a SS or M900 Airbox
couple of hours on the dyno.
if you really want to make it, I would go for a FCR kit modified with a TPS so that you can link it to the IGNITECH and have MULTIPLE MAPS; there is an FCR kit with TPS already fitted on but will need to be sligtly modified with spacers and jets/needles; SUDCO (also on google there are different posts) can help with that
Anyway, I would NOT change a thing on the 907, the P7 is very reliable and if there are any problems 99.999% of the times is just due to POOR , VERY POOR maintenance.
Often the problems can be addressed to:
- bad pickup, cables become hard with age and tend to break internally.
- wrong pickup distance; the PU need to be within a certain distance from the flywheel to work properly
- clogged fuel filter, it needs changing quite often, it is too small for a 900CC with 80BHP, but is a pain and not always the mechanics (lazy) replace them.
- failing sparkplug wires
- failing TPS sensor or more often , wrong setting.
- wrong CO setting, has to be done toghether with the TPS setting.
- overall poor electrical connections.
- bad P7, it is rare but can happen.
PostPosted: Mon Oct 25, 2010 4:13 pm
what do you do with the SS/M900 airbox ? There`s no other airbox that fits in the Paso frame specially not those ones. The front section of the Paso frame not as wide as on those models.
Kokusan CDI boxes will work as well.
I don`t know about the 907ie engines but on some newer ones you need to weld some material to the engine case so you can mount the pick up bracket.
I can`t really understand why to carb convert an IE unless the bike is incomplete or the engine is replaced. A bike with FCR carbs rides definetely different though than one with an injection system.
PostPosted: Tue Oct 26, 2010 12:04 am
PostPosted: Thu Oct 28, 2010 12:17 am
PostPosted: Thu Oct 28, 2010 11:49 am
Cheers Claude.
PostPosted: Thu Oct 28, 2010 12:14 pm
PostPosted: Thu Oct 28, 2010 1:37 pm
