ducatipaso.org • View topic - 750 Paso Wiring Upgrade to Improve Starting
It is currently Mon Sep 29, 2025 5:45 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jul 15, 2005 11:31 am
 Post subject: Wiring Mod.
PostPosted: Fri Jul 15, 2005 4:24 pm
PostPosted: Sat Jul 16, 2005 8:00 pm
PostPosted: Sun Jul 17, 2005 10:05 am
PostPosted: Sun Jul 17, 2005 10:09 am
PostPosted: Mon Jul 18, 2005 4:50 am
PostPosted: Mon Jul 18, 2005 7:53 am
I discovered the reason of the blown fuses!
There's an error in the schematics taken from my shop manual.
Here's the schematics:
as you see it's indicated a 7.5A fuse for the G-BK line.
Here's the shop manual:
as you see, the same fuse (F2) is 15A !
Obviously the right value is 15A.
LC
PostPosted: Mon Jul 18, 2005 7:57 am
Luca,
Was it a 7.5A before you changed the wiring ? or did you change all the fuses atthe same time ?
Paul
PostPosted: Mon Jul 18, 2005 8:05 am
It could be 15A but I am not sure: when I checked the resistance of the lines I detached all the fuses and replaced them following the schematics indications...
(what a mistake!)
LC
PostPosted: Mon Jul 18, 2005 8:07 am
I will have a look at mine when I get home tonight and let you know what I have. Mine is an '87 model.
Paul
PostPosted: Mon Jul 18, 2005 11:01 pm
Ok I have already done the coil wiring mod and tonight did the main relay one not that I had a starting problem more of a dimming head light when using the indicators, not good at night!
Anyway why is there a 7.5amp fuse? Connected to an orange wire, which if you trace it back to the connecting block under the fuel tank is not connected to anything?
PostPosted: Tue Jul 19, 2005 1:28 am
PostPosted: Tue Jul 19, 2005 4:32 am
PostPosted: Tue Jul 19, 2005 10:21 am
PostPosted: Tue Jul 19, 2005 2:07 pm
Users browsing this forum: No registered users and 125 guests
