ducatipaso.org • View topic - not all BATTERIES are the same !!!
It is currently Thu Oct 29, 2026 10:58 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: not all BATTERIES are the same !!!
PostPosted: Sat Oct 30, 2010 10:53 am
since '92 I have replaced many batteries on the paso, usually I bought a yausa (same as original) but was never happy with them, in early '07 I purchased a Deka EXT16 275cca, this is a sealed battery and used often with harleys...although I've neglected it...it has never let me down and came to the conclusion that next time I wouldn't buy anything else but a Deka...has anybody else tried this battery on their bike?
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
 Post subject: Re: not all BATTERIES are the same !!!
PostPosted: Sat Oct 30, 2010 11:56 am
Dekka.in my experience is the most trouble free option currently readily available :thumbup:
PostPosted: Sat Oct 30, 2010 3:50 pm
they say also the Odyssey are good.
But there is thread where such thing has been already discussed.
PostPosted: Sun Oct 31, 2010 1:30 pm
I have a few of them in my bikes and they are all doing a good job.
PostPosted: Sun Oct 31, 2010 2:53 pm
PostPosted: Sun Oct 31, 2010 8:13 pm
I have just now very bad experiencies about YUASA battery in my ST2, as its more expensive and least ONLY 2 summers with very good maintain... Ok, this was ST2 battery, but anyway i dont buy anymore Yuasa battery, as also cheap ones least same 2 years. I am electrician and i really know, how to maintain batteries....
PostPosted: Mon Nov 01, 2010 4:11 am
Odyssey gel cell batteries are very good. I have one in my ST4s and I also put one in my ST2 before I sold it. A very solid battery. A little more expensive, but rock solid. The Sport has some other brand battery, and is very kind to batteries, but when it goes, I'll put in the Odyssey battery. The early ST2 has a questionable charging system, and benefits from a tolerant battery.
PostPosted: Mon Nov 01, 2010 8:36 am
from the relay to the starter motor I have the standard factory cable and the bike always starts within one or two seconds...deka seems to have a lot of grunt :thumbup:
Cheers Claude.
PostPosted: Mon Nov 01, 2010 10:11 am
Just my personal experience,but I have had issues with the gel cell type batteries. Much better luck with the Glass Mat type.
PostPosted: Mon Nov 01, 2010 11:12 am
I have Deka.
I read that gell batteries don't like being overcharged or completly discharged either, so a AGM,absorbed glass mat, is far more robust/strong.
The odessy site has more info
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Mon Nov 01, 2010 11:20 am
Cheers Claude.
PostPosted: Mon Nov 01, 2010 12:14 pm
PostPosted: Mon Nov 01, 2010 12:26 pm
Cheers Claude.
PostPosted: Mon Nov 01, 2010 2:48 pm
Where to you get the Deka?
PostPosted: Mon Nov 01, 2010 3:22 pm
Got mine from these guys
Also worth mentioning except for the 1st year ST2 all ST models are 3 phase stators, no Paso's came with or can easily be made 3 phase, cases and crank would have to be changed out or you would have to find someone willing to try a 3 phase wrap of the stator, nearly impossible to do. nearly all 3 phase stators spin the magnet around the outside of the stator due to the negative effects of hysterisis
