It is currently Thu Oct 29, 2026 11:27 am
 Post subject: cdi problem
PostPosted: Fri Dec 03, 2010 3:51 am
hi im new in the forum and i buy a ducati paso 750cc 1988 year but the problem is dont have the cdi unit and i dont find the cdi , one knows If i can make a adaptation for the cdi from oder bike?? :shock: :thumbup:
 Post subject: Re: cdi problem
PostPosted: Fri Dec 03, 2010 6:51 am
Why have you written here and not in the 750 section?
No matter, you have many options.
Try searching on 750 forum and you'll find many tips until to fit an EFI on your Paso.
Obviously you can also try to find the stock ECU on ebay or elsewhere...
Good luck :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Fri Dec 03, 2010 8:39 am
Add your location to your profile and we`ll be able to guess what CDI unit you have. Most common are 2 Kokusan units (same as on 600/750/900 Monster/Supersport/Paso/Cagiva Elefant). Some later Pasos, most seem to be in the US, have a Marelli Digipley unit. Which one are you looking for and if you don`t know how does the connector to the cdi box(es) look like.
PostPosted: Tue Dec 07, 2010 4:12 pm
thank for your help :thumbup:
