ducatipaso.org • View topic - Decent Exhaust Pipes?
It is currently Mon Sep 29, 2025 11:15 am
Post new topic Reply to topic  [ 134 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Post subject: Re: Decent Exhaust Pipes?
PostPosted: Wed Nov 24, 2010 10:33 pm
Rhino
Renegade exhausts at Brands Hatch may still be around - they used to make pipes to order - you can borrow my Lazers as a pattern if you want ?
Actually if you can find someone UK based to make them you can borrow them as a pattern for anyone.
Definitely try giving Baines racing a call to see if they know of a UK source for cans or someone who will make them.
Definitely go with Stainless or Ti if you get the chance the sound is better (crisper) carbon can get blown apart unless its carbon sleeve over Ti construction and then you may aswell have Ti !
Blue flame will make a slip on Can that will probably do the job (as will just about any manufacturer) it will be the link pipe that is the problem but there are still decent exhaust builders out there (none spring to mind at the moment though)
a quick google search produces these guys
http://www.osmc.co.uk/exhaust.htm
NRP who have already mentioned
http://www.gazbike.demon.co.uk/
These guys might be interested too
http://www.mtcexhausts.co.uk/index.htm
I'm thinking of just getting a set of link pipes made so I can break out to more commonly available silencers as and when I need
I may have mislead you earlier
TTS and PDQ are Dyno tuning companies for setting the fuelling up once you've got the cans etc.
You may be abel to get away without a chip in any case and just use a TFI box from techlusion as its a pretty simple fuel injection setup
PostPosted: Sat Dec 04, 2010 11:12 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sat Dec 04, 2010 11:41 am
Claude - Ti is the atomic (Periodic) shorthand for Titanium
Rhino
If God rides a Harley . . .
Then the Devil rides a Duke!
PostPosted: Sat Dec 04, 2010 8:38 pm
Most decent Carbon cans are Carbon wrap over a Ti sleeve - termis and Feraccis are I believe - the problem with some of the all carbon ones on big twins is they get blown apart over time which is not so good.
Carbon has an inherent ability to isolate vibration and therfore dampen sound so it tends to make the exhaust note more "woofly" than a stainless or Ti can which is more crisp.
The up side to carbon is that it also is cooler to the touch which helps a lot with High level pipes or underseats
There's naff all performance benefit between the same two cans made in say Ti or Carbon normally as the intenrals are the same, lengths the same etc etc.
PostPosted: Mon Dec 06, 2010 12:55 pm
Cheers Claude.
PostPosted: Mon Dec 06, 2010 1:16 pm
The only reason I ever acquired any of that knowledge is that I used to own a Suzuki TL1000- the standard question asked by those guys is how to make it sound better first which I always found odd as it should always have been how to make it handle better first and sound later.
PostPosted: Mon Dec 06, 2010 1:21 pm
PostPosted: Mon Dec 06, 2010 1:34 pm
G
Yoshi carbon cans are carbon/Ti sleeve and have been for about 8 years I think. I believe Akra are too
Most of the UK manufacturers are too now for quality stuff.
As carbon starts to become a less desirable material I think more will switch and the wrap will get thinner and thinner until we end up back at a Ti can again :lol:
Regarding absorption type silencers I think most new to the market - aftermarket cans for the UK are absoprption type as it makes the core very easy to remove for More noise or more performance for the Gixxer brigade and can be replaced easily at MOT time
I would imagine doing that in Germany probably results in a not very nice telling off and a failure of the TUV test :shock:
Like that digram by the way
PostPosted: Wed Dec 08, 2010 12:14 am
Staintunes on ebay
PostPosted: Fri Dec 17, 2010 11:02 am
I have just posted this on the thread Its mine and Finally Home
I have just been told about (and I am about to execute) a small alteration to the exhausts to get the rumble (you and) I want. I am informed (Tony Brancato of Brancato Ducati Engineering - a life-time on Dukes) that there is, in the very end of the silencers on the 907 a set of baffles. These baffles were not intended by the factory but were forced on them by various legislation in various countries (esp the USA). This baffle is located at the very end of the pipes and is held in place by two very small spot welds. These were designed by the factory to retain the baffle and are very easy to grind out and, if neccessary, replace by re-inserting and re-spot welding.
This modification - I AM TOLD - will not neccessitate any alteration to the engine set up at all (as after market pipes might).
I have just spoken (3 minutes ago) to the engineer where my bikes now are and he confirms the spot welds and the small baffle. I have instructed him to "get cutting".
I won't hear it run until I next see the bikes in February but I will let ya'll know.
(must find out how do do quotes)
Rhino
PostPosted: Fri Dec 17, 2010 8:32 pm
I did a similar mod to mine. removed the baffle put in a larger end pipe then machined out the outlet cap to match the larger pipe and rivitted the whole thing back together. I am very pleased with the somewhat deeper and slightly louder with out being raucous note
PostPosted: Sat Dec 18, 2010 12:00 pm
Higgy - I'd love to see a picture of those pipes on the bike
Rhino
PostPosted: Sat Dec 18, 2010 5:34 pm
I have as yet not had the time to finish the project,can't decide if I like it better in solid black or with the aluminium cover or maybe do something in some flavor de stainless
I plan to do a backpressure study in the near term but overall with just one side done it runs much better. I don't know what chip I have in it and the airbox is modified with a K&N filter
BTW, the diffuser went back in and is held by a single rivot so that I may remove it easily should I decide to modify it a little more as time goes by.
PostPosted: Sun Dec 19, 2010 9:47 pm
Higgy,
Do not just restrict your exhaust cover options to those mentioned. As the pipe does not get very hot I've had great results covering the aluminium sleeve with plastic adhesive wrap (the stuff you line shelves and drawers with) and this has included; carbon fiber, wood grain (a nice oak finish), black speckeled marble (for that classic look), patterened stainless. The plastic wrap has never bubbled or melted and I just change it to suit; like every other year.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Mon Dec 20, 2010 9:53 am
Thanks Higgy - very informative - I love the pipes:- BLACK! Too cool
Rhino
