ducatipaso.org • View topic - Any suggestions?
It is currently Tue Apr 28, 2026 8:36 am
 Post subject: Any suggestions?
PostPosted: Thu Dec 09, 2010 10:32 pm
My top mount, the "ears", for my frame mount of rear shock is a little loose,
around 0.35 mm. If you lift under the wheel to check f freeplay,
(as Swedish MOT test does....), it feels like 2 mm.
Any idea how to fix this?
Weldable at all?
 Post subject: Re: Any suggestions?
PostPosted: Fri Dec 10, 2010 12:24 pm
Gert, is it broken (what would you weld)...or does the suspension linkage have worn parts (bush/bearing)
is the 2 mm play measured at the shock or at the rear wheel...2mm is not much if at the rear wheel
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Fri Dec 10, 2010 1:32 pm
The ears on frame where the top bolt is mounted are worn.
Doesn`t bother me or compromise driving,
main problemo actually MOT inspection.
+ it would be nice to fix it, if doable.
PostPosted: Fri Dec 10, 2010 2:02 pm
PostPosted: Fri Dec 10, 2010 6:07 pm
I would say too a 2 mm. play is not a problem.
Are you sure that when you'll do the MOT inspection will there be some problem?
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Sat Dec 11, 2010 12:56 pm
The "extreme solution" is to drill one of the two ears and build a special bolt with different size related to the two ears.
Anyhow, a .35 mm freeplay should not be your matter, expecially if the bolt is correctly tighten.
Have a nice job and...
PostPosted: Sun Dec 12, 2010 12:39 am
OK, thx.
Think I`ll skip the job.
