ducatipaso.org • View topic - Shim kit info
It is currently Mon Mar 02, 2026 5:05 pm
 Post subject: Shim kit info
PostPosted: Sun Jan 02, 2011 1:34 am
Hi, I need to do a valve adjustment what (mm) kit do I need?? Also what company do you guys think has the best deal??????? :?
 Post subject: Re: Shim kit info
PostPosted: Sun Jan 02, 2011 3:05 am
You need a kit for the early 2-valve engines.
Check out these rental tools:
PostPosted: Sun Jan 02, 2011 7:01 am
Have a look here:
http://www.emsduc.com/products.html
and here:
http://www.emsduc.com/assets/ducati_shim_chart.pdf
:beer:
PostPosted: Tue Jan 04, 2011 7:46 am
Make sure your motor is absolutely cold, in other words it has not been run that day, when you measure your clearances, otherwise your measurements will not be correct. If you need more clearance, you can simply remove metal from the tappet by stoning.
PostPosted: Tue Jan 04, 2011 9:15 am
PostPosted: Wed Jan 05, 2011 1:28 am
Thanks guys :beer:
