ducatipaso.org • View topic - New adjustable preload rear shock
It is currently Thu Apr 30, 2026 11:27 am
 Post subject: New adjustable preload rear shock
PostPosted: Thu Jan 20, 2011 12:19 pm
Hi guys, just thought someone may be interested in what i fitted to my 907ie.
The standard shock was rebuilt but the rebound faded out after a short period which was the original problem. I was warned that rebuilds on these are not always successful.
I purchased a new rear shock (marzocchi) from ebay for a 750/906. Prior to buying it i asked for the dimensions and compaired it to my original.
The hole centers were the same so i thought i`d give it a try on the 907. Here are some pitures.
I had to wind the preload down about 10mm using the lock nuts to set the ride height after i noticed the tyre had rubbed a bit on the plastic under guard with a pillion, that was with the extra preload wound up from the remote adjuster as well (backed right off when solo though).
The shock fells good now i think i have it sorted out. It doesn`t have compression damping only rebound at the base.
 Post subject: Re: New adjustable preload rear shock
PostPosted: Thu Jan 20, 2011 12:30 pm
Sorry stuffed up pitures. Working on problem. Re-reading instructions...Der!
PostPosted: Thu Jan 20, 2011 12:40 pm
done. [img] at the beginning and the end of the links was double that`s why they didn`t work
PostPosted: Thu Jan 20, 2011 12:52 pm
Do you normally see the pictures in the preview screen? Or just the link?
PostPosted: Thu Jan 20, 2011 12:59 pm
Take two..............
PostPosted: Thu Jan 20, 2011 1:57 pm
Nice...how hard was it making up a bracket for the preload adjuster? It didn't just bolt on, did it?
Sam
PostPosted: Thu Jan 20, 2011 2:13 pm
PostPosted: Thu Jan 20, 2011 5:01 pm
that seems the old marzocchi unit fitted on the PASO 750.
I got one of those, it is basically the same as the 907 one (overall dimentions), the only big difference is that the spring is different, the 907 one is 2 times harder; then the internal setup will match the harder spring, however I was told it could work also as it is.
PostPosted: Thu Jan 20, 2011 9:10 pm
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Thu Jan 20, 2011 9:26 pm
whats the going rate ie price for one of these and ann original for a 906? :) :cool: :thumbup:
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Thu Jan 20, 2011 11:14 pm
PostPosted: Fri Jan 21, 2011 11:06 am
Hi, yes i agree the spring may be a bit soft. It doesn`t seem to be an issue solo though. I will be trying source a harder one i think. The original spring won`t fit as it is shorter.
The Bracket i made for the remote adjuster was fitted using the 2 bolts holding the rear brake master cylinder.
I paid roughly $150AU for it.
PS, I don`t understand? I couldn`t get the pictures to work in the first thread, now they are there? Sorry poeple that you have to look at them twice...............
PostPosted: Fri Jan 21, 2011 12:46 pm
