It is currently Thu Feb 26, 2026 5:36 pm
| Author |
plasmid
Post subject: Paso Dash Posted: Sun Mar 06, 2011 11:46 pm |
Joined: Mon May 10, 2010 9:49 pm Posts: 366 Location: eu/us
Greetings.
Does anyone have a schematic for how the dash/instrument pod is supposed to be mounted or secured?
Mine is kinda bouncing up and down. Initially I thought the foam is supposed to keep it in place but maybe not.
Thanks.
| Top |
JoKing
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 4:51 am |
Joined: Mon Jun 20, 2005 12:00 am Posts: 362 Location: Northern Germany / Kiel
It is mounted 3x with the shock mounts (#12).
Don`t think these are available anymore my dealer told me, I bought the last ones available.... But maybe that was only for Germany, or he lied...
_________________ 92` Ducati 907 i.e. - ST3-Conversion --> Burned down with my barn 78` Ducati 900 SS - Bevel --> Sved her by risking my life 90` Cagiva Freccia C12R - Paso`s smaller sister --> Burned down with my barn 86` Ducati 750 Paso 96` Cagiva 750 AC Elefant
| Top |
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 11:31 am |
| paso grand pooh-bah |
Neoprene Vibration Damping Sandwich Mount Male/Male, M4 X 0.7, 1/2" Height, 3/8" Width 9225K61 (Same as 9376K201)
These are cheap and with a little shortening of the threads work just fine. Here in the states they are availible through McMaster Carr
| Top |
JoKing
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 1:03 pm |
Wow.... thats much less than I paid... (~5€/piece)
| Top |
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 1:52 pm |
it`s like the fork seals. They cost €33 at Ducati and 9,95 at a Polo/Hein Gericke etc. store
| Top |
plasmid
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 2:13 pm |
| Top |
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 3:06 pm |
mounts are threaded on both ends with rubber in between. One end threads into the cluster( the end you need to shorten) the other is nutted in place on three brackets that are part of the fairing stay
| Top |
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 3:09 pm |
they usually come appart one day as the threaded part is only glued to the rubber block. The foam rubber surround is there just to close the gap between instrument panel and fairing.
| Top |
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 6:40 pm |
$1.58 at McMaster-Carr
| Top |
plasmid
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 7:14 pm |
| Top |
plasmid
Post subject: Re: Paso Dash Posted: Mon Mar 07, 2011 7:15 pm |
| Top |
JoKing
Post subject: Re: Paso Dash Posted: Tue Mar 08, 2011 12:01 pm |
| Top |
Post subject: Re: Paso Dash Posted: Tue Mar 08, 2011 12:06 pm |
One of the reasons why these silent blocks fail can be the speedometer cable. There are several cables that fit but if the one used is not long enough there can be tension on it which will transfer on the silent blocks. One of the signs the speedometer cable was replaced with one that`s too short is that the rubber retainer on the side of the fender is stretched when the wheels are on the ground or the front is lifted.
| Top |
Post subject: Re: Paso Dash Posted: Tue Mar 08, 2011 12:07 pm |
€2 for a fork seal is sensational ! Where is that ?
| Top |
Users browsing this forum: No registered users and 5 guests |
