ducatipaso.org • View topic - Odometer
It is currently Thu Oct 29, 2026 7:13 am
 Post subject: Odometer
PostPosted: Mon Mar 07, 2011 10:31 pm
Another dash related issue
Has anyone taken their odometer apart?
Mine started working intermittently so I suspect one of the plastic gears broke.
I've seen places that fix this in the US but this bike is in Germany,
so I'm considering taking it apart.
Anything to watch out for / not break something else?
 Post subject: Re: Odometer
PostPosted: Mon Mar 07, 2011 11:21 pm
intermitent issues are not likely to be internal to the speedo,more likely a cable, drive or receiver issue :thumbup: If in fact it proves to be internal be very careful and good luck finding parts aside from a spare speedo :wacko: Get your cluster installed properly and check that cable then go from there :?:
PostPosted: Mon Mar 07, 2011 11:53 pm
PostPosted: Tue Mar 08, 2011 4:06 am
could still be the cable,if either end is worn
PostPosted: Tue Mar 08, 2011 11:57 am
Don`t think so, when the trip meter still works.
Maybe i have a used, but working odometer somewhere...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Tue Mar 08, 2011 12:42 pm
PostPosted: Tue Mar 08, 2011 7:58 pm
I found it.
The dash holding rubber/screws you should purchase somewhere else. I paid much too much for them.
The fairing stay rubbers i got as well. You got a PM.
86` Ducati 750 Paso
