ducatipaso.org • View topic - Frame numbers / register?
It is currently Tue Sep 30, 2025 2:21 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Frame numbers / register?
PostPosted: Sat Mar 19, 2011 6:33 am
Looks like the factory was busy in October '91. That seems to be when mine was date stamped. Red with frame no. 1573 and engine no. 1494. Gold Brembos. So at least 278 bikes were made in 10/91 from Dennist's 1322 to Duc907's 1600.
Randy
'92 907ie Ducati
'68 Harley/Aermacchi (65cc!!)
'89 GB500 Honda
'79 CBX Honda
'86 Honda Spree (50cc)
'60 Harley Topper
Einstein's theory of relativity: GO FASTER, YOU WILL LIVE LONGER
PostPosted: Sat Mar 19, 2011 7:36 am
My red one is Nr. 866. Must be a 91 with black front Brembos, 300mm Disc and black exhaust
First registered March 92. 17800 km
Always keep the rubber down
Ducati 907 i.e. 1992
BMW R1100RS 1993
PostPosted: Sat Mar 19, 2011 3:30 pm
PostPosted: Wed May 25, 2011 8:42 pm
mine is 2179 just 124 from the last one off.
PostPosted: Thu May 26, 2011 1:38 pm
Then mine is only 18 from the last one... :mrgreen:
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Tue May 31, 2011 2:25 pm
Mine is 315, Antti knows it well, I think he tried to buy it...
got it in 2001, 27K km on the clock, when I bought it it was preatty much standard, then I fitted Brembo Gold Brakes (full system) and Discacciati full floating Rotors (front), braided hoses, open Airbox , K&N and Ferracci chip; I also fitted a lightened sprocket set (-2 teeth rear sprocket) and a DID EVR 520 racing chain.
Next will be a complete overhaul of the suspensions, as soon as I manage to find a missing front tube..... :banghead: :banghead:
PostPosted: Sat Aug 20, 2011 6:26 am
my nummer is 522 april 1991
PostPosted: Sat Aug 20, 2011 3:54 pm
so mine is a Model-Year 1991, Black P32-Brembos with 300mm-Discs, (Wheels were cast in 1989/1990, the Instruments in Panel had sticker with year 1988 stamped on :? )
Frame number 475
Engine number 395
She was first registered in Feb. 1993
Modifies are: F1-Exhaust, Black-painted (not plastic-coated) Rims, Rear seat handle, Triple clamps and Instrument- housing, White Wheel rim-Sticker with text, Instrument sheets in white with self-made design. Optimized Fork and Rear Shock.
Users browsing this forum: No registered users and 97 guests
