ducatipaso.org • View topic - fuel tank return ?
It is currently Sat Mar 07, 2026 10:10 pm
 Post subject: fuel tank return ?
PostPosted: Thu Mar 10, 2011 7:55 am
Is there supposed to be a fuel return line on my 88 paso? im running 38 mikunis and the only connections on my tank are fuel out and what seems to be a vent line at the very rear of the tank that runs to atmosphere. shayne
 Post subject: Re: fuel tank return ?
PostPosted: Thu Mar 10, 2011 11:08 am
yes, there should be an Y connector before the carbs and the return line should go to the rear connection on the tank.
PostPosted: Thu Mar 10, 2011 6:52 pm
That diagram shows two i only have one, if i apply pressure to it,it builds up and when released escapes back from this line. will the fuel pump pressurise the tank? how does it breath (vent)
cheers
PostPosted: Fri Mar 11, 2011 8:47 am
I`ve never seen a Paso tank that only has one connection on the rear right. The tank needs the vent exit. The gas cap seals well enough to create an underpressure in the tank if the vent line is closed or clogged. There have been some topics about this issue.
Photos are always welcome.
PostPosted: Fri Mar 11, 2011 10:25 am
g, a little background on this bike, i purchased it from a friend and it had sat in a container for 6 years ,after recommishining it allways started first press but fouled plugs after aprox 500-700km
which i put down to running rich, after reading through several search results i stumbled across the posted diagram of the tank decal which got me thinking i was over pressurising the carbs ( running rich) bike runs great but after hard runs wants to stall when pulling up, again ,thinking over pressure.will try to post a photo of underside of tank but unable to till monday, got a ride on through the weekend.
cheers shayne
PostPosted: Fri Mar 18, 2011 11:11 pm
G, heres the photo of my tank[img]htpp://s1128.photobucket.com/albums/m482/maxpaso
/[/img]
well that didnt work, first go at posting pictures i,ll have to read the instructions again
PostPosted: Sat Mar 19, 2011 5:53 am
this is how your link shold look:
http://i1128.photobucket.com/albums/m48 ... eltank.jpg
While yours look like this:
htpp://s1128.photobucket.com/albums/m482/maxpaso/
PostPosted: Sat Mar 19, 2011 8:22 am
sorry about the stuff up i,m still trying work this business out. question still remains, if i run an overflow from the feed to this vent/return line will it serve any purpose?
shayne
PostPosted: Mon Mar 21, 2011 7:13 pm
I`m speechless. I`ve never seen a Paso tank w/o return line.
If you use the breather as a return line you could run into fuel delivery problems due to underpressure that builds up in the tank. I think this would only work if the filler cap would breathe.
In case your fuel pressure is too high there`re several options like using a fuel pressure regulator, swap the electric fuel pump with an underpressure fuel pump or try a return loop as shown below. "7" is a jet that reduces diameter.
PostPosted: Mon Mar 21, 2011 8:59 pm
G,
Just add to the confusion, my 750 Paso fuel tank is exactly the same as Maxpaso; no return line.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Mon Mar 21, 2011 9:38 pm
elder pasos have no fuel return line, have a look to the spare parts catalogue to see how they are.
Mikunis and Dells need no fuel pump and no return line to run.
PostPosted: Mon Mar 21, 2011 10:24 pm
PostPosted: Tue Mar 22, 2011 8:28 am
the only thing i can think of is that i dont have a charcoal canister so it does,nt need one. im running 38 mikunis,standard paso pump,bike starts instantly when cold runs well pulls hard but after a sustained run,when coming to a stop she splutters and wont come back to idle, couple of good revs ,returns to idle was thinking i might be flooding bowls while float is hanging.
Fraser, what carb/s are you using? do you vent your fuel line?
G, thanks for the pic of that set up. Im thinking to tee back to vent and try to vent my cap, can,t be that hard. just another thing on the paso to work out. :thumbup:
PostPosted: Tue Mar 22, 2011 10:08 am
I wonder how venting a filler cap would work. One would need a valve. If you just remove the rubber seal you´ll have fuel spilling over the tank as soon as you put the bike on the side stand.
PostPosted: Tue Mar 22, 2011 9:06 pm
Maxpaso,
I have some Mikunis, still have the fuel pump (easier to leave it than remove) and the fuel line is vented.
Fraser.
750 Paso
2013 Yamaha MT-01
