ducatipaso.org • View topic - Rebuilding my 907 ST3
It is currently Tue Sep 30, 2025 4:32 pm
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 12  Next
 Post subject: Re: Rebuilding my 907 ST3
PostPosted: Sat Mar 12, 2011 6:29 pm
PostPosted: Sat Mar 12, 2011 6:40 pm
Yes, the upper forward mount on the right side is still at the paintshop... :roll:
The lower won`t be used.
I think i do not need it. But i am not sure. I will test it.
The ST3 engine offers no possibility to use it.
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Wed Mar 16, 2011 5:04 pm
Today i flooded the frametubes where possible with fluid film, to prevent oxydation damage.
86` Ducati 750 Paso
PostPosted: Sun Mar 20, 2011 10:25 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sun Mar 20, 2011 8:26 pm
Sprocket& swingarm-axis are exactly on the same hight.
How does it look like in original?
86` Ducati 750 Paso
PostPosted: Mon Mar 21, 2011 10:01 am
See a special tool, a green toothbrush. Recognizable, and also in my toolbox present. . . . :lol:
Proud owner of a;
- Ducati 907 ie 1992 in red
PostPosted: Mon Mar 21, 2011 4:07 pm
86` Ducati 750 Paso
PostPosted: Mon Mar 21, 2011 6:11 pm
JoKing, Looking that toothbrush: Too dirty teeths !!! Use more toothpast ! Do You have to kiss Your wife still ?
PostPosted: Mon Mar 21, 2011 6:14 pm
:lol:
86` Ducati 750 Paso
PostPosted: Sun Mar 27, 2011 1:47 am
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Sun Mar 27, 2011 10:35 am
after looking at both pics, the front sprocket looks to be in the same spot, (my apologies for barking up the wrong tree) it just didnt look right, I should of taken the cover off and had a proper look...then the swingarm chain damage was most likely caused by a loose chain, had a look at my swingarm and it also has a little chain groove, but very small, a chain guide or nylon pad might not be a bad idea to prevent this and check chain tension more often :beer:
Cheers Claude.
PostPosted: Sun Mar 27, 2011 4:16 pm
How is the mileage of your bike?
Mine has altogether about 145.000km on the odo...
86` Ducati 750 Paso
PostPosted: Mon Mar 28, 2011 3:13 am
not many, 17,623km
Cheers Claude.
PostPosted: Mon Mar 28, 2011 4:04 am
I think you will have the same damage, when your bike reaches the 146tkm...
86` Ducati 750 Paso
PostPosted: Mon Mar 28, 2011 5:20 am
you could be right...when I get some time I'll remove the sprocket cover and inspect if there is any damage near swingarm bearing, I still think this is not a design fault, but a maintenance issue :beer:
Cheers Claude.
Users browsing this forum: No registered users and 76 guests
