ducatipaso.org • View topic - How many Horsepower
It is currently Tue Sep 30, 2025 6:37 pm
 Post subject: How many Horsepower
PostPosted: Mon Mar 28, 2011 10:35 am
My 907ie stod in a Garage for 10 years. Al the papers are lost. All i have is a copy of the old Document.
My Duc was directly imported from Italy. Did they had a version with 58 kw/78 Horsepower in Italy?
My copy says 58kw/8500rpm. Could that be ?
The manual says 66kw/90 Horsepower.
What is right. I need this information to get new papers from the German Tüv.
Always keep the rubber down
Ducati 907 i.e. 1992
BMW R1100RS 1993
 Post subject: Re: How many Horsepower
PostPosted: Mon Mar 28, 2011 11:18 am
the Aust brochure I'm looking at says for the 907 57.5kw @8,500rpm at rear wheel, the other figure of 66kw may be at the flywheel.
thats for the 91 model, should be the same for the 92 model.
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Mon Mar 28, 2011 11:19 am
maybe JoKing can send you a copy of his papers even if it`s not the same model year.
PostPosted: Mon Mar 28, 2011 11:40 am
I have two Dynocharts. I think one came from the forum and one I found in the internet. Both show 73,4-74,5hp at rear wheel. So the 78hp should be fine.
Other (higher) values were probably measured at the clutch or driveshaft. It`s like the P750. It`s often mentioned with 72hp, if you check german magazine tests, they usually stated 64.
testrun_907ie_a.jpg [57.91 KiB]
Downloaded 880 times
PostPosted: Mon Mar 28, 2011 11:58 am
Thank´s for the fast information. Can anybody send me a copy of a German 91 Model Fahrzeugbrief or Zulassungsbescheinigung
Teil 2.
Many Thanks
BMW R1100RS 1993
PostPosted: Mon Mar 28, 2011 11:59 am
Have a look at my scan
907_1_91_001.jpg [152.82 KiB]
Downloaded 878 times
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Mar 28, 2011 12:08 pm
Thank you so much.
The answers are that quick.
:thumbup: :thumbup: :thumbup:
BMW R1100RS 1993
PostPosted: Mon Mar 28, 2011 12:27 pm
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Mon Mar 28, 2011 4:57 pm
right, I forgot that :)
PostPosted: Fri Apr 01, 2011 1:47 pm
looking at G's secong graph...is that the torque figure, it doesn't look right, max torque @ 2500rpm...
this 907 must of been fitted with a diesel engine :dunno:
Cheers Claude.
PostPosted: Fri Apr 01, 2011 4:13 pm
Its correct.
Mine from before the engine-swaps looks the same. Not that much HP, but it looks equal.
86` Ducati 750 Paso
PostPosted: Fri Apr 01, 2011 10:36 pm
PostPosted: Sat Apr 02, 2011 12:18 am
Cheers Claude.
PostPosted: Sat Apr 02, 2011 4:41 am
Here you can see some 907s curves.
The green curves show my 907 before the conversion, with 130tkm on the odo.
The red one is the much "younger" 907 with lower mileage.
The Blue one is the same one with slightly optimized engine.
(This bike is for sale, it is the frame # 2000)
/Edit: You see KW. To get HP, you have to multiply the values by 1.36
On this picture you can see my 907 engine, compared to the first run after the conversion. This was with a Multistrada 1000DS-2-Valve-mapping.
Its sad i have no torque-curve and the later, optimized curves saved.
But when i have finished my reassembly, there will be a new run, i think...
86` Ducati 750 Paso
PostPosted: Sat Apr 02, 2011 11:29 am
Interesting graphs, thanks for sharing...that green line shows a fairly tired motor, not much happening untill 3300rpm.
I might put mine on a dyno now that its running the best thats its ever done :beer:
Cheers Claude.
Users browsing this forum: No registered users and 60 guests
