It is currently Sat Oct 31, 2026 4:43 am
 Post subject: Fork Seals
PostPosted: Fri Apr 01, 2011 5:40 am
I need to replace the fork seals on my 750 Paso Does anyone know of a good source for these?....or like everything else on these bikes are they made from "Unobtainiam"?
Thanks in advance,
Jeff
 Post subject: Re: Fork Seals
PostPosted: Fri Apr 01, 2011 2:22 pm
Jeff add your location to your profile.
Assuming you are in Germany I could tell you where to find them but you`re probably not.
The original ones are 41,7mm 55mm 10/10,5mm (inner diameter, outer diameter, height/height of seal lip). 41,7 55 8/10,5 works also fine.
Go to any bike shop that sell parts, clothing etc with the dimensions and check if they have or can order them. Most shops don`t have a problem getting them.
What parts of a Paso are unobtanium ? Other than the instrument cluster cover I couldn“t think of one.
PostPosted: Fri Apr 01, 2011 9:53 pm
Hi Jeff,
just did the oil & dust seals on mine , got the oil seals of these guys
http://cgi.ebay.com/Ducati-Paso-750-198 ... 43a1a3b64a
they are also on trademe.co.nz .
Got my dust seals from here
http://www.ducati-gowanloch.com/catalog ... c5b78c6e62
Happy hunting :D
1990 750 Paso
2011 Suzuki Bandit 1250 S
