ducatipaso.org • View topic - Three tyres solutions?
It is currently Sun Jun 21, 2026 12:01 am
 Post subject: Three tyres solutions?
PostPosted: Tue Apr 05, 2011 12:02 pm
Hi, I'm Ivan, from Spain, just registered.
I will buy a 750 Paso and researching for tyres and this stuff. Last night I found these three available sizes, think will fit perfectly, but I'm not sure.
These are:
160.70.16. Metzeler M1
170.70.16. Bridgestone G722 Exedra
Dunlop K555
130.70.16 Metzeler M3 Sportec
Bridgestone BT016 Battlax
Dunlop Sportmax Qualifer 2
Found in www.rodamoto.es and www.neumaticos-pneus-online.es
Hugs from Spain
 Post subject: Re: Three tyres solutions?
PostPosted: Tue Apr 05, 2011 6:25 pm
you will find many topics here. it has been discussed up and down.
A 130/70-16 front is fine. For the rear it`s 150/80-16 or 180/60-16.
The 160/70-16 doesn`t exist anymore. There was only one tire and that was discontinued. A 170/70 is too high.
PostPosted: Tue Apr 05, 2011 10:07 pm
mmm... I'll go for 160/70 unit. But ¿150/80 works fine? I dont like to install a 180
regards
PostPosted: Wed Apr 06, 2011 7:39 am
look through this or the 906 forum, you`ll find all the info.
If you find a ME1 it`s most likely an old tire (check DOT number) unless Metzeler is producing it again which I doubt as about no bike tire shop lists it.
PostPosted: Wed May 11, 2011 4:02 am
hi i find a front tire is a 110 / 80 /16 but i dont find more tires here in my country is it ok? or funcionality? :shock:
PostPosted: Wed May 11, 2011 8:02 am
no, not ok. A 110/80 is made for a rim with 2.5-3.00" width max.
Add your country to your profile so we know where you are.
PostPosted: Fri May 13, 2011 2:29 am
Users browsing this forum: No registered users and 28 guests
