ducatipaso.org • View topic - Starter not engaging.
It is currently Mon Sep 29, 2025 7:54 pm
 Post subject: Starter not engaging.
PostPosted: Sat Apr 09, 2011 8:36 pm
I have a 91 907ie and the starter seems to only engage for about 2 revolutions before it cuts out the starter keeps spinning but the engine doesn't what could the problem be?
Also how do you test to see if ignition coils are bad (ohm resistance etc)?
 Post subject: Re: Starter not engaging.
PostPosted: Sat Apr 09, 2011 9:10 pm
sounds like the starter sprag clutch. Just search the forum.
PostPosted: Sat Apr 09, 2011 9:57 pm
G. is mentioning one possible cause.
the other can be that the starter turns to slow due to loss of voltage.
this can be caused by worn brushes, bad contacts.
also about this can be found on the forum.
Bertus
PostPosted: Sun Apr 10, 2011 5:47 am
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Sun Apr 10, 2011 11:50 am
The 907 has most of the "fix's for electrical issues as is.
But the only fix for the passage of time is maintenance
Clean those grounds and connectors. You will have far fewer issues :thumbup:
PostPosted: Sun Apr 10, 2011 1:29 pm
and disconnect the clock ( orange wire) as the clock drains the battery rapidly.
Bertus
PostPosted: Sun Apr 10, 2011 9:28 pm
PostPosted: Sun Apr 10, 2011 10:07 pm
never understood what probelms all guys have with their clocks. Mine is just fine and there`s never been a battery problem even if the bike wasn`t started for a few weeks.
PostPosted: Sun Apr 10, 2011 10:37 pm
under the seat there are 4 fuses, remove 2nd (from right) and clock will be disabled.
I remove the fuse during winter.
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Mon Apr 11, 2011 2:07 pm
Cheers Claude.
PostPosted: Tue Apr 12, 2011 3:10 am
I think you guys with clock problems are missing something deeper.
My bike gets ridden only every few weeks at the moment with periods of up to a month without a start. The battery has never discharged to a degree where the bike wouldnt start. Perhaps its time to look further into this mystery that affects bikes in the Northern Hemisphere.
:zip: :zip:
:banghead:
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Tue Apr 12, 2011 5:26 am
It has been my experience with my 907 if the idle is too low,low enough to get a flickering charge light at idle the charge on the battery lets the clock draw it down to no start in about two weeks.
PostPosted: Tue Apr 12, 2011 1:29 pm
Users browsing this forum: No registered users and 31 guests
