ducatipaso.org • View topic - How to Set the TPS for the 907
It is currently Sat May 02, 2026 7:00 pm
 Post subject: How to Set the TPS for the 907
PostPosted: Tue Apr 19, 2011 7:45 pm
Can anyone tell me what the factory settings are for the 907 using a digital volt meter? I'm going to try to see if the TPS is off and if that's why it dies when you nail the throttle or try to go over 5500 rpm.
Ed
'93 Ducati 907ie, '01 Ducati ST4, '07 Honda ST1300A
 Post subject: Re: How to Set the TPS for the 907
PostPosted: Wed Apr 20, 2011 1:12 am
http://home.kpn.nl/duran103/pics/p7-p8.pdf
Basic setting is really only:
Wind out idle & throttle stop screws til they don`t affect tps.
Remove cover of big AMP connection into ECU.
Measure + & - mV at pin 11 &17. When correct: 150 mV +/- 2mV.
Recommended Idle mV I haven`t seen but around 270-350 mV seems plausible.
Just set mine, idles at 300.
PostPosted: Wed Apr 20, 2011 1:16 am
but a dvom may not be the BEST tool :thumbup:
PostPosted: Wed Apr 20, 2011 1:25 am
The best tool is ......?
PostPosted: Wed Apr 20, 2011 2:21 am
analog
PostPosted: Wed Apr 20, 2011 4:29 pm
Ed
PostPosted: Wed Apr 20, 2011 10:33 pm
:thumbup:
