ducatipaso.org • View topic - new tires on paso
It is currently Fri Jun 19, 2026 5:57 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: new tires on paso
PostPosted: Fri Apr 29, 2011 8:33 pm
Check to see if your forks are slid up in the triple clamps.
that's a common trick to get the steering quicker, which is understandable with a Paso. It steepens the rake a bit, but looses clearance.
Also check the pre-load spacers on your forks. A previous owner may have shortened the spacers to soften the forks a bit.
Or, you may have soft springs in the forks.
PostPosted: Fri Apr 29, 2011 8:55 pm
Thanks for the tips,
One thing is for sure and it´s that my front shocks are in need of service. I just got new seals so have to check on the other things you mentioned while replacing them.
PostPosted: Sat May 07, 2011 8:17 pm
Just an update on the alternative tires I've shod the Paso with on her Marvic/Akront wheels:
I've ridden over 3000 miles on the 120/70 r16 Michelin Pilot Sport and 140/70 r16 Pirelli Diablo and they are wearing mildly, and gripping with veracity. I have no complaints, it seems the 140 is just wide enough to bring great satisfaction into the corners. Good feedback has kept me from riding over the edge. I'm pleased as punch with the rubber: No destruction or injury, just good times up right to the limit.
I don't ride with a pillion. That would overburden the tires.
Best to all, and Happy Mother's day!
—Randy.
PostPosted: Mon Jun 27, 2011 6:46 am
OK, it´s time for a little update since my Paso is running again.
What I did was serviced the front shocks (new oil & dust seals), replaced the front brake pads, got a new speedometer-thingy (the one that makes the cable rotate) and also replaced the speedo-cable with a fresh one.
BUT!
The front tire (130/70-16 Bridgestone BT016) still touches the front of the fairing when braking. Not if I brake gently but if I use, say a moderate pressure, theres a contact.
So what to do next? The shocks are now mounted normally, not slid up even one bit. Also the forks are now serviced. I wouldn´t want to cut the fairings to make room for the tire, but it seems that´s the only option left. (Or remove the fairings and make a streetfighter Paso... sometimes I´m still intrigued by the idea)
PostPosted: Mon Jun 27, 2011 10:43 am
@ pasoist
i am using a 130 / 70 Avon tire in the front. I do not have any clearance problem in the way you discribe it.
infos and pictures here:
viewtopic.php?f=2&t=4463
PostPosted: Mon Jun 27, 2011 3:28 pm
PostPosted: Mon Jun 27, 2011 8:54 pm
what about those short metal tubes that put some compression on the fork springs when the top cap is screwed on. If those are missing the fork would also dive in more.
Btw what`s the proper position of the fork in the upper triple clamp ? Should the top end be on one level with the triples upper edge or should the fork actually touch the steering half ? That would probably make 1cm difference.
PostPosted: Tue Jun 28, 2011 7:57 am
@ angelix:
i´m pretty sure the oil level is not an issue, since I poured in/measured the oil myself. The manual says 350cc and that´s what I measured.
@G:
I´ve been wondering the same thing myself. The fork tubes were slid as up as possible (so that the top of the tubes touched the handlebar mounts) before I serviced the shocks. Now the top of the forks are aligned with the triple clamps. So I guess there could be an extra centimeter worth of clearance for the front fairing. Don´t know how the forks are supposed to be mounted. Or is it safe to slide them further down in the tripleclams?
PostPosted: Tue Jun 28, 2011 11:53 pm
