ducatipaso.org • View topic - source for piston rings or piston set
It is currently Sat Oct 31, 2026 4:44 am
 Post subject: source for piston rings or piston set
PostPosted: Sun May 01, 2011 6:41 am
does anybody know a good source for piston rings or piston sets in europe which are decently priced?
also for the top conrod bushing?
i've seen a couple of cars that have 88mm pistons but the oil ring is too thick (5mm, 2mm more than the original paso 750) and i can't rectify it as the other top ones.
 Post subject: Re: source for piston rings or piston set
PostPosted: Sun May 01, 2011 8:31 am
if you want new pistons it´ll be hard as they were discontinued. Maybe some old Ducati dealer still has some in stock. Otherwise there´re used ones on ebay and Ferracci is selling 90mm big bore pistons and 88mm pistons as conversion of 600 Monsters. Don´t know if the last will also be good for a Paso though.
For piston rings and bushings check Stein Dinse in Germany.
http://www.sd-tec.de/catalog/product_in ... 3d892d42e4
PostPosted: Sun May 01, 2011 9:12 am
thanks for links!
the piston rings look very dear if they charge for single piston.
if i have no choice i'll probable get a set of vw 88mm rings and rectify them to right size.
PostPosted: Sun May 01, 2011 10:43 am
I got my piston rings exactly at the same price (170€ for both cylinders) 4 months ago in the Ducati dealer. They are coomen parts, expensive though,
PostPosted: Sun May 01, 2011 11:44 am
Complete set piston and rings 75usd about 50eu plus shipping
