ducatipaso.org • View topic - Left M1r fork leg needed!
It is currently Thu Mar 12, 2026 10:39 am
 Post subject: Left M1r fork leg needed!
PostPosted: Fri Apr 15, 2011 1:00 am
The one w no rebound fuction.
My wheel axle threads are gone, need just the lower part of left M1r leg.
 Post subject: Re: Left M1r fork leg needed!
PostPosted: Fri Apr 15, 2011 4:44 am
try iangowanloch@bigpond.com he may have one...good luck :beer:
actually this one might be better gowanloch@ozemail.com.au
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sun May 29, 2011 10:35 am
did you find a leg I am looking for the RH side leg
PostPosted: Sun May 29, 2011 3:04 pm
Not found.
PostPosted: Sun May 29, 2011 3:19 pm
if Gert finds one it won`t help you as the 907ie fork is not the same.
PostPosted: Thu Jun 02, 2011 9:31 pm
I thought the lower was the same but the actual tube longer, or are the threads different too?
PostPosted: Fri Jun 03, 2011 8:31 am
the 907ie has 40mm brake caliper mounts, the P750/906 has 108mm.
Gert has a 907ie, avhpaso a P750.
PostPosted: Fri Jun 03, 2011 9:52 am
Got you, wasn't thinking about calipers (but should have been)
PostPosted: Mon Jun 06, 2011 10:53 am
seen this ?
It doesn`t say which Paso it`s from, the price is a bit high and the position of the left dust seal looks a bit odd considering all seals were replaced :mrgreen:
http://cgi.ebay.de/Marzocchi-fork-41-7- ... 415a61a926
PostPosted: Tue Jun 07, 2011 9:50 pm
