ducatipaso.org • View topic - oil leak - 750 paso
It is currently Mon Jun 15, 2026 7:01 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 22, 2005 4:30 pm
Luca,
Many thanks for your response too!
I have, previously, read some of your previous postings and it is all interesting stuff and I will ensure that I check that everything is standard and that the transmission is 'in line'!
As per my previous posting I have already begun to strip the bike and have yet to, thoroughly, assess the damage and I have already phsyched myself up to expect the worst case scenario possible, (then if things are not quite as bad then things are looking up)!
I have already had two, (local), offers for the re-welding and I fully appreciate the need to find a piece of Paso crankcase for 'testing' purposes - else what started as a 2cm x 1cm gap soon becomes a 20cm x 10cm write off!
Once I have convinced MS Frontpage 2003 to publish my web site, (correctly), I will post a regular diary so that you can all experience the emotions, (that I am sure to experience), during the forthcoming restoration!
And I am sure that I will have many further questions to put to the group, (such as how the dash is supposed to be mounted - as mine is just a 'push fit' between a framework of foam rubber and that can't be right)!
I may attempt to remove the engine, tomorrow, as I am not due to return to work untill Wednesday, and I am hoping that I will not have to cut anything else off in order to get it out!
Was in your 'neck of the woods', (four weeks ago), as Julie and I visited Rome, (for the first time), but did not have time to visit Bologna on this particular occasion!
Take care and ride safely!
PostPosted: Mon Aug 22, 2005 4:54 pm
I think that your "rebuild diary" is a great idea and I'm looking forward to see it as soon as you start your work! :lick:
Bye!
LC
PostPosted: Tue Aug 23, 2005 12:58 am
Hey Martin,
I checked out your web Site & was pretty impressed with it. I enjoyed (& cringed a bit ) reading of your French expedition, definately on of the worst holidays I have read about.
So what happened to your 916? I gather it was totalled but you are a bit short on details.
Good site :thumbup:
Redpaso
PostPosted: Tue Aug 23, 2005 8:34 am
Just because I have a little more spare time... here are some photos of my repair with alluminium welding.
the welded case (still leaking):
the 1st try with red silicon gasket film to stop leaking:
the 2nd try with black silicon gasket film to stop leaking:
the gearbox lay shaft (sproket) gasket substituted:
... but oil still leaking!!
LC
 Post subject: Not Enough Hours In The Day !!
PostPosted: Tue Aug 23, 2005 11:53 pm
Users browsing this forum: No registered users and 70 guests
