It is currently Mon Sep 29, 2025 1:24 am
 Post subject: Alternator cover
PostPosted: Thu Jun 09, 2011 7:42 pm
I am trying to get the alternator cover off with the engine in the frame so that I can replace a duff starter motor. The cover has moved by 2-3 centimetres with the aid of a puller but now seems jammed on the side stand anchor point. Am I missing something or do I have to take the engine out of the frame to get the cover off. Can it really be that difficult ?
 Post subject: Re: Alternator cover
PostPosted: Fri Jun 10, 2011 7:36 am
remove the lower frame rail if the cover hits it.
PostPosted: Fri Jun 10, 2011 8:19 am
Thanks.
Clearly I was missing something. I am too used to old British bikes with one piece frames. I will remove the left hand cradle which looks like that should allow the cover to come off so that I can get at the starter motor bolts.
