ducatipaso.org • View topic - Front Sprocket
It is currently Mon Jun 15, 2026 3:01 pm
 Post subject: Front Sprocket
PostPosted: Wed Aug 24, 2005 3:46 pm
Has any body tried putting a Fast by Ferracci front sprocket on? I just tried and it mounts flush with the countershaft. There is no way I could get the locking plate on. Did they send me the wrong one? Or is there an adapter plate that I need?
Donna G
'12 Moto Guzzi V7Racer
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Wed Aug 24, 2005 5:53 pm
Are You sure, that they give Paso sprocket to You ???
Is offset same ???
Finnpaso
PostPosted: Wed Aug 24, 2005 6:14 pm
Finn,
I called them and they said to just turn it around. I can't get the stupid thing off w/out a puller, but even so....the sprocket is still the same length. I'm pretty sure the shoulder will still cover the groove that the locking plate goes into.
:roll:
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Wed Aug 24, 2005 6:39 pm
:cool:
You must be able to get it off without a puller, Bard. It must need a little jiggling, maybe a little lube, and a little (gentle) force PARALLEL to the splines.
PostPosted: Wed Aug 24, 2005 7:24 pm
I ordered a front sprocket from BCM. They by accident sent the wrong one . They then had to special order new one, took about 2 weeks. The guys there are great!
Good luck
Theo
PostPosted: Thu Aug 25, 2005 4:09 am
Got the sprocket off and turned it around. Of course it's the same size and still sits flush to the end of the countershaft. There is no way to hold it on.
I did notice a threaded hole in the end of the shaft. Could that be for a different type of lock washer or something?
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Thu Aug 25, 2005 4:34 am
:cool:
No, the threaded hole would be part of the shaft-making process. Are you sure you're puting the sprocket all the way on, past the gap in the splines where the locking plate sits? If it won't go on that far, it must be the wrong sprocket - same as with Theo.
What did you think about some barding for the 'Apex' forum, by the way?
PostPosted: Thu Aug 25, 2005 5:38 am
Thanks for the info skins. I'm sick and tired of working on this thing tonight so I'm gonna walk away from it for awhile. HOPEfully I can get the right sprocket. Is it best to buy the sprockets and chain as a set?
As far as writing for the apex....probably should wait till I'm in a better frame of mind with this bike. Nobody would want to hear what I have to say about it right now! :cool:
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Thu Aug 25, 2005 7:48 am
:cool:
Yes, it would be best to replace sprockets and chain together, unless the one you're not replacing happens to be in good condition, because a worn sprocket will quickly cause wear on a good chain, and vice versa.
It can take time to make a Paso good, Bard - even when they came out of the factory they could be made better - but when you get one right, they're a wonderful bike, with a touch of complexity to make them interesting. Their weight helps make them comfortable, yet they feel like a small bike with very light steering, and their 750 motor, which is torquey yet revvy, makes good hp, and can be made to be incredibly smooth. With a bit of effort, one can get results which would be hard to achieve with most other bikes.
PostPosted: Thu Aug 25, 2005 12:20 pm
PostPosted: Fri Aug 26, 2005 9:18 pm
:thumbup:
Good idea, Jon. Obvious, but good. And these bcmducati people do sound good. I'm sure the Bard would get good advice there.
I do like your flag. I'm sure the Captain would have approved most heartily!
PostPosted: Sun Aug 28, 2005 3:00 am
Jon, and Skins...
thanks for the info. I'll check out BCM next time I'm in need of a fix. I've hopefully gotten things straightened out with the orders and will find out when they get here this coming week.
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Thu Sep 01, 2005 1:13 pm
PostPosted: Thu Sep 01, 2005 7:58 pm
:thumbup:
Excellent! Thanks, Jon.
Users browsing this forum: No registered users and 57 guests
