ducatipaso.org • View topic - Rebuilding my 907 ST3
It is currently Thu Apr 30, 2026 12:50 pm
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 12  Next
 Post subject: Re: Rebuilding my 907 ST3
PostPosted: Mon Jun 13, 2011 9:39 am
no airfilter ? Are two different airhorn lengths standard ?
Claude, would that also matter with a temperature sensor ? I could imagine that`s more a problem of pressure sensors but I don`t really now.
PostPosted: Mon Jun 13, 2011 10:13 am
pic 1:
Fitted w. "no toil"-like airfilter. The "dirty" look comes from the blueish filter oil.
pic 2:
lower part "installed"
pic 3:
fits nice
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Mon Jun 13, 2011 10:18 am
86` Ducati 750 Paso
PostPosted: Mon Jun 13, 2011 10:24 am
pic 1:
view from above w. top of irbox fitted
pic 2:
lower "lid" of the opening fits to frame
pic 3:
upper "lid" of the opening fits to frame. The frame triangle behind the steering head is used as a part of the airbox this way. (see also pic 1)
Maybe the opening is too large, but we will see.
86` Ducati 750 Paso
PostPosted: Mon Jun 13, 2011 10:26 am
when I had issues with the FI chip I was seriously thinking in shifting the press sensor away from box but never did, changed chip instead...the 907 has a water temp sensor, but no air temp sensor...(I didnt understand your question G) :dunno:
I would fit the press sensor in some sort of small open container away from air turbolence, with this major modification there is a bit of trial and error...
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Mon Jun 13, 2011 10:57 am
Last edited by Tamburinifan on Mon Jun 13, 2011 11:14 am, edited 3 times in total.
PostPosted: Mon Jun 13, 2011 11:04 am
PostPosted: Mon Jun 13, 2011 11:05 am
PostPosted: Mon Jun 13, 2011 11:35 am
The equipment/parts are available. only the position needed.
I think i will position it somewhere near the intake, so the temperaturedifference caused by oil & water cooler to the real intake temperature will be as low as possible.
86` Ducati 750 Paso
PostPosted: Mon Jun 13, 2011 11:43 am
86` Ducati 750 Paso
PostPosted: Mon Jun 13, 2011 11:47 am
Cheers Claude.
PostPosted: Mon Jun 13, 2011 11:50 am
I just got an answer from a guy who developes mappings for Porsche & develops different "intake kits" for cars and so on. He advised me to position the sensor directly in the airflow to the intake.
86` Ducati 750 Paso
PostPosted: Mon Jun 13, 2011 11:57 am
That is maybe correct position in theory, I don`t know.
I meant that your ECU expects Air Temp sensor to be somewhere in front, under fairing,
like on the bike it once where placed on & map software developed for.
Probably no biggie placing it elsewhere, just away fr engine heat.
Last edited by Tamburinifan on Mon Jun 13, 2011 12:08 pm, edited 2 times in total.
PostPosted: Mon Jun 13, 2011 12:02 pm
I just saw the Air s yesterday, on my airbox, just next to blue MAP 3wire sensor.
Brown 2wire connector to it, sorry no pic.
PostPosted: Mon Jun 13, 2011 12:22 pm
I will have a better look next time...never noticed a temp sensor :wacko:
Gert youre knowledgeable re FI system...what happens if you disconnect the air press hose and re-positioned elsewhere away from air box...I was contemplating this instead of the cigarette butt trick :dunno:
Cheers Claude.
