ducatipaso.org • View topic - Bottom-end compatibility 750 <> 907ie
It is currently Fri Feb 27, 2026 9:02 am
 Post subject: Bottom-end compatibility 750 <> 907ie
PostPosted: Wed Jun 29, 2011 7:16 pm
Can anyone give a quick but well informed answer to this naiive question:
Is the bottom-end of the 750 the same as for the 907? Can I rebuild the heads from the 907ie onto a 750 bottom-end, with all its auxiliary stuff like water pump??
thanks
Easier to get an answer here than hope I get the answer right by inspection / documentation review.
 Post subject: Re: Bottom-end compatibility 750 <> 907ie
PostPosted: Wed Jun 29, 2011 8:18 pm
no it`s not.
The 750 is an oil cooled, 5 speed gearbox engine with 88mm pistons, the 907ie is a water cooled, 6 speed gearbox engine with 92mm pistons.
Due to the different gearbox the 907ie engine case is a little wider and the cylinder stud distances are bigger due to the larger pistons. Of course the engine case opening for the cylinders is also larger.
PostPosted: Wed Jun 29, 2011 11:30 pm
