ducatipaso.org • View topic - Fuel line connections
It is currently Fri May 01, 2026 12:17 pm
 Post subject: Fuel line connections
PostPosted: Fri Jul 08, 2011 6:46 am
Today's issue: I failed to properly mark the fuel line connections coming out of the bottom of the tank. There are four spiggots. From the front to the rear, the first is the out line, the second the return line. One of the two rear spiggots is for the overflow...but the other? Vent perhaps. Of these two, which is which? I think the rearmost is for the overflow. Any suggestions?
Many thanks,
Randy
'92 907ie Ducati
'68 Harley/Aermacchi (65cc!!)
'89 GB500 Honda
'79 CBX Honda
'86 Honda Spree (50cc)
'60 Harley Topper
Einstein's theory of relativity: GO FASTER, YOU WILL LIVE LONGER
 Post subject: Re: Fuel line connections
PostPosted: Fri Jul 08, 2011 8:12 am
Randy, check p.28/29 of the user manual (you find it in the downloads if you don`t have it).
PostPosted: Sun Jul 10, 2011 11:25 am
Many thanks G. I knew I saw the diagram somewhere.
Randy
'92 907ie Ducati
'89 GB500 Honda
'79 CBX Honda
'60 Harley Topper
