ducatipaso.org • View topic - Mikuni ID
It is currently Tue Sep 30, 2025 11:18 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Mikuni ID
PostPosted: Thu Jul 21, 2011 10:02 pm
Hey guys, new Paso owner here. The Paso 906 I got a few weeks ago came with Mikuni carbs. One of the carbs is missing some kind of needle/jet that goes in from the bottom of the carb(right next to the float bowl). I don't know what these carbs came off of, I do know that the bike ran ok with them before the missing piece. I need to get a new one and don't really know were to start. I believe they are BDST carbs. Is the any way of identifying he carbs?
Thanks for any info,
Conor
 Post subject: Re: Mikuni ID
PostPosted: Fri Jul 22, 2011 1:15 am
Do they look like this ?
These are off a 97 900SS :)
PostPosted: Fri Jul 22, 2011 1:50 am
I think so...here are some pics.
This next one shows the missing needle on the left carb.
PostPosted: Fri Jul 22, 2011 5:43 am
Before you find another needle , try the needle from the other carb , just to make sure the reason there is no needle is not because the thread is stripped in the carb body :)
PostPosted: Fri Jul 22, 2011 5:52 am
Good idea!! Just checked and its fine. What is the name of that needle?
Conor
PostPosted: Fri Jul 22, 2011 7:59 am
that`s the idle mixture screw.
That Mikuni is the same on all carbed 600, 750, 900 Monster & SSs, some Cagiva Elefant models, Yamaha TDM/TRX 850 etc.
Pls add your location to your profile.
PostPosted: Fri Jul 22, 2011 8:30 am
as suggested above Conor, remove the other idle mixture screw not just to use as a thread-checker on other carb, but because it needs a closer inspection in itself.. it shouldn't be sitting with the screw head exposed like that - it's usually quite recessed down it's 'tube'. Fingers crossed that it's only adjusted wrongly, but if it's the std needle then it can hardly have engaged the first thread judging by it's appearance/positioning.
PostPosted: Fri Jul 22, 2011 9:49 am
PostPosted: Fri Jul 22, 2011 6:21 pm
PostPosted: Sat Jul 23, 2011 2:41 pm
PostPosted: Sat Jul 23, 2011 3:39 pm
btw not sure but I might have a spare cover incl. idle mixture screw. I would need to check.
PostPosted: Sat Jul 23, 2011 8:33 pm
ya let me know if you do and want to sell it G.
Conor
PostPosted: Sun Jul 24, 2011 4:00 am
PostPosted: Sun Jul 24, 2011 5:33 pm
Giocast, unfortunately you´re right.
PostPosted: Tue Jul 26, 2011 10:56 pm
