ducatipaso.org • View topic - paso parts needed..
It is currently Fri Feb 27, 2026 11:37 pm
 Post subject: paso parts needed..
PostPosted: Mon Aug 29, 2005 5:56 pm
i'm looking for:
ignition switch w/key
tail piece lock assembly w/key
left side oil cooler cover
seat (anythings better than the ratty one i have...)
i'm in ohio...
thanks!
-Greg
PostPosted: Tue Aug 30, 2005 5:18 pm
Greg, you`ll find all parts on ebay except to the keyswitch.
If yours has "only" contact problems you can carefully take it apart (beware there`s a spring and a small metal ball inside that may fly away when you open it). Usually some bad contact built up resistance and cause some parts to heat up and melt. So inside the switch on the contacts there might be some burnt plastic you should just remove to make it work again. I`m sure this was already discussed here before. Search some older posts.
Gerhard
PostPosted: Thu Sep 01, 2005 1:07 pm
Greg,
Don't waste your time repairing the ignition switch. Buy a new one. I've done it all before, you will end up in the middle of nowhere, cursing the day you bought a Ducati. I did it on my old 900GTS, and it would last for months, and the next time only days. I think I did it on my SS Darmah, and the service agents in Sydney(bloody Frasers) did it against what I instructed, stuffed it, and had to replace it with a new one. Once the contacts inside are corroded, they never clean up properly or fit together with tight clearances.
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Fri Sep 02, 2005 3:55 am
it doesn't have a keyswitch assembly at all, i have it hotwired. i guess i could just stick a universal keyswitch in there and at least have something...
what i really need is a seat though...
PostPosted: Fri Sep 02, 2005 12:57 pm
I have a seat in that barn. I'll take a pic and send it you you. drop me an email jcslocum@hotmail.com. It's from an 87, black in decent shape.
PostPosted: Thu Sep 08, 2005 9:07 am
Hi see the post i left in the 750 section there is a few parts that you need there you may be able to get them to post you the bits.
the seat was a little dark but intact. the bike came from japan.
Rodney
