It is currently Sun Apr 26, 2026 3:42 pm
 Post subject: I need a 906 or 907 subframe
PostPosted: Sat Jun 11, 2011 1:24 am
Anyone know of a 906 or 907 sub frame (frame headlight and gauges bolt to) that is for sale? The 750s are not the same. To many modifications to be made. One leg of the 907 is bent to get around the radiator hose on one side along with fairing
bumpers and the mounts for the electrics and catch tank.
Du907
 Post subject: Re: I need a 906 or 907 subframe
PostPosted: Sat Jun 11, 2011 11:52 am
spotted this on ebay
http://cgi.ebay.com/ebaymotors/1990-90- ... ccessories
1990 750 Paso
2011 Suzuki Bandit 1250 S
PostPosted: Sun Jun 12, 2011 9:04 pm
Thanks for the look Foxtee. I saw that one also but the description says it was bent. After my wreck, so is mine and it is to hard to figure out what is still correct and what is bent. So I want to try and get one that is not bent so at least I'm starting with a straight or factory spec piece.
PostPosted: Mon Jun 13, 2011 8:50 am
you have a pm
PostPosted: Mon Jun 13, 2011 2:14 pm
thank you paso750. I am persuing the lead.
PostPosted: Fri Aug 05, 2011 8:17 pm
Im still looking for a subframe. The 750s are not the same as the 907. There are a lot of attachment points that are not the same and the fairing bumpers are located differently.
Any help is much appreciated.
du907
PostPosted: Fri Aug 05, 2011 8:37 pm
here`s one that requires some straightening
or this one which looks much better
http://cgi.ebay.de/Halter-Verkleidungso ... 45fbff8161
PostPosted: Sat Aug 06, 2011 2:53 am
Nice looking piece. The listing doesn't say anything about shipping to the US if my German is any good. I have some friends that live near Munchen, Herrsching I think.
du907
PostPosted: Sat Aug 06, 2011 9:30 pm
the second one is in the Kassel area. several hours drive from Munich.
the part looks realy nice. the seller doesn't send to USA, according his ad.
But if you contact him, maybe he changes his mind.
I got the same results from Paso parts out of the USA.
If you want, I can it for you, as the seller will ship to the Netherlands.
then I can send it to you. I don't need any fees. just the price of the frame and the shipment costs
Bertus
