It is currently Fri Jun 19, 2026 1:57 pm
[ 5 posts ] |
| Author |
desmodave
Post subject: regs and wires Posted: Mon Aug 01, 2011 4:58 pm |
Joined: Sun May 07, 2006 12:00 am Posts: 150 Location: castleford.west yorkshire.england
When i changed from the original regulator on my paso i was left with 2 green wires a red wire and a pink wire. ....what are these for? anyone!
does the pink have to be grounded for the bike to charge? is this the batt charge light?
all these wires are left in the original conector left side-open.
also when i tried the wiring upgrade i was only half succesful-the coil end didnt work for me. ive noticed avatars photos were intresting as the block showed one red on top(same)a brown(where my black is)another brown underneath(mine is red)and so are the blocks different? as wires must be different for each persons bike.
my bike was okay to ride home after my crash as the dash lit up-but now i come to try it no dash lights or ignition.
now another funny thing the engine WILL try to turn over with kill switch off!!! still no dash lights though.
HEELLLP!
| Top |
Post subject: Re: regs and wires Posted: Thu Aug 04, 2011 11:07 am |
| paso grand pooh-bah |
Dave, did you have a look at the wiring plan ? The two green wires are the ones that come from the alternator, as does the red one. The pink wires is for the batt. charging light. I wonder how your new regulator works if these wires are still unused ?! Do not ground the batt. charging light if it is unused !
I`m not sure I understand your comments about the coil wiring. It is actually very easy.
My guess is what you describe as brown are the discoloured orange wires. I must admit that at the moment I`m not sure if it`s normal that the starter motor runs also with kill switch on OFF as what it mainly does is kill the ignition. (cut the 12V to the coils)
Does your headlight and taillight work ?
| Top |
desmodave
Post subject: Re: regs and wires Posted: Sat Aug 06, 2011 12:43 pm |
| Top |
desmodave
Post subject: regs and wires Posted: Mon Aug 15, 2011 8:43 am |
dont be shy lads anything would be appreciated!!!
| Top |
jayh
Post subject: Re: regs and wires Posted: Mon Aug 15, 2011 9:54 am |
Joined: Thu Oct 22, 2009 10:38 am Posts: 247 Location: Mildura ,Australia
This is from the downloads section, J.
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 19 guests |
